The more I read about this 'exploding' stove, the more skeptical I become. There were 'problems' from day one but what were they? Was the stove burning poorly causing the glass to get coated with creosote? Did the homeowner try to clean the 'glass' with a scraper, razor blade, or steel wool, which would scratch the 'glass' and create stress risers that would propagate when the admitted overdose of pellets finally ignited with the usual poof? Some serious analysis of the saved pieces of glass should uncover that possibility.
We are all pointing fingers at the manufacturer without REALLY knowing the background facts.
The problem was that the stove shut down in the middle of the night the second night it was on.
Then it shut down once every couple of days from then on. Often at inconvenient times of night.
My husband would thoroughly clean the stove and then start it up again. It would burn fine for 12/ 24/ 36 hours and then shut down again. We were cleaning the stove around once every day (way more than you should have to) and we're using around 3 bags of pellets per day (apparently also way more than normal).
No issues with the glass - we just cleaned it with plain water on a paper towel. No razor blades (!) steel wool (!!) or anything else.
Several times (like 3 or 4) over the month that we had the stove the shut down was accompanied with a 'whirring' sound. That's when we thought the feed tube was blocked.
I am honestly completely taken aback by the accusations that we are somehow at fault for this. We have read all the directions, watched countless YouTube videos on cleaning, asked lots of questions here and called and emailed the supplier on many occasions.
Had anyone told us that we should not restart it because it might EXPLODE we would obviously not have restarted it ever.
I did a lot of research on pellets, both on here and on google. We even rented a van and drove an hour to buy a test ton of Barefoot pellets because we heard they were the best. In addition we bought Energex which we had good luck with last year and O'Malleys which were recommended as the most premium pellet the supplier carried.
We paid for a top of the line stove, paid the store to install it and have followed every direction since receiving the stove.
Thankfully neither the tech who came to view it, nor the manufacturer have given the slightest indication that we did anything wrong. If they do I would seriously consider involving an attorney because frankly the idea that this has been somehow our own fault is completely unfair and ridiculous.
You should not have to be a 'minister of fire' to effectively run a pellet stove.
