Hi everyone, new member here. Just working on a self build, stealing some design ideas from the burley wood stove vortex. (i have built tluds and rocket stoves but never a wood stove)
I have just started laying out, cutting my steel and welding caps in most places that need them and i have a couple of questions before i continue.
Stove dimensions will be roughly
16 deep
22 tall
18 wide
1. how much space is needed above the baffle?
2. how much space between the outer wall and the lip of the baffle?
3. Should all the primary air come out in front of the door or should it come up under the wood?
4. How large should the air holes be? I will be making them adjustable just looking for a rough idea for primary, the vortex tubes, and the top secondary/third burn in this case.
Any other suggestions are welcome. I have attached pics of layout plus some with sharpie marks showing primary air options.
![Experimental stove. Looking for self-build advice! Experimental stove. Looking for self-build advice!](https://www.hearth.com/talk/data/attachments/292/292601-7a560b5e6c56c4f152cbff34566b6ed6.jpg)
16 deep
22 tall
18 wide
![Experimental stove. Looking for self-build advice! Experimental stove. Looking for self-build advice!](https://www.hearth.com/talk/data/attachments/292/292596-80207c92ebe424dc920668b9a4ce24d1.jpg)
![Experimental stove. Looking for self-build advice! Experimental stove. Looking for self-build advice!](https://www.hearth.com/talk/data/attachments/292/292597-c852ab326760848273c992d4c6a7b1ef.jpg)
![Experimental stove. Looking for self-build advice! Experimental stove. Looking for self-build advice!](https://www.hearth.com/talk/data/attachments/292/292598-f6e78c7db8816fce523da37bd66491e8.jpg)
![Experimental stove. Looking for self-build advice! Experimental stove. Looking for self-build advice!](https://www.hearth.com/talk/data/attachments/292/292599-c37bcc99972ebd28c4551d06e32b19d4.jpg)
![Experimental stove. Looking for self-build advice! Experimental stove. Looking for self-build advice!](https://www.hearth.com/talk/data/attachments/292/292600-6fe0061887c62696a7995c3bc4844f61.jpg)
