![Experience with sooteater Experience with sooteater](https://www.hearth.com/talk/data/attachments/238/238440-befe14653609191fa7c1c355e4ef0185.jpg)
If it was not for this site, I would not know such a tool existed.
Why did you unhook the pipe? I just run through the bypass with the vacume hose in the stove no messView attachment 238413 For the first time I cleaned my chimney “bottom up “ with a sooteater today. It was safer and warmer than going up on a lader in January. I have to say it took about the same amount of time (I was taking my time though). Slightly more messy. The sooteater did a good job.
Nothing wrong with the way you did it there is just an easier wayIt is a telescopic pipe. I did not think it will go through the bypass. Now I know. You confirmed it, thank you.
A SootEater will be on my Christmas list next winter.
As for removing the stove pipe or going up the bypass, the Pacific Energy (Super 27) stove manual states:
"Chimney connector pipe should be disconnected from stove to clean and inspect.
Only if this is not possible should you remove baffle assembly."
I do see that in most posts people talk about removing the baffle for the PE before cleaning (which seems simple), yet this thread makes me wonder which route should be taken.
I just heard about this sooteater device. I am glad to have heard about it before using a poly brush on my delicate smooth wall chimney pipe. Unfortunately, I did not do my total research till after the fact and found that the lifetime smooth wall flex chimney pipe was not that great. I was warned that using a Poly brush to clean it will damage the insides of this pipe. Unsure of the next steps, I found this sooteater which was recommended for this type of chimney pipe. Hope it works well and prolongs my chimney pipe but so far, all I hear are good reports on this rotary chimney cleaner in addition to being able to clean my chimney cap as well.....cant wait to try it and see for myself personally...
The unsupported bottom edge of that extremely thin inner layer can get snagged by the brush when pulling up. Retailers say lots of stuff to up sell stuff. Allot of it is bs. If you want smoothwall get heavy wall or midweight stuffI keep hearing how delicate smoothwall liners are but some of the places that sell them say they are superior construction and the only reason to buy single wall corrugated is to save money.
Hard to imagine how a poly brush could hurt the smooth wall.
I’ve been using a sooteater in two smooth wall liners for the last 6 or 8 years. No issues. I have also read others state problems with smooth wall liners, and I understand the concern, but it’s not as if standard flex liners are forever, either. My personal experience has been fine, but I will likely not spend the extra coin for smooth wall in the future.
I once disconnected my telescopic pipe to run a sooteater through, not that big of a deal for cleaning but I said "NEVER AGAIN" once I realized not only is it a major pain to get a pipe to actually telescope back out but also lining up the holes for the probe thermometer coupled with the stubborn telescoping made me go nuts. Because it's not a simple up/down telescopic motion once the pipe gets the slightest bit of soot on it (residual from your hands even) you have to do some twisting to get it out. That's where you majorly screw up keeping the probe holes lined up.
Hey that is some good info issues on using a telescopic stove pipe I would have never thought of - although I don't have any on my stove. Maybe you should clean it in the same method as you normally do prior to the Sooteater but instead use the sooteater. Seems you changed you not only the tool but also the method of cleaning it.
I always dropped the baffle and just cleaned from the bottom up. Let's just say curiosity got the best of me that one day and I thought "hmm maybe this would be easier to clean if i disconnected the pipe....." NOPE![]()
Make a small witness mark first on the pipe with a pencil that crosses both sections. That will be your alignment guide when lowering the pipe back down.Because it's not a simple up/down telescopic motion once the pipe gets the slightest bit of soot on it (residual from your hands even) you have to do some twisting to get it out. That's where you majorly screw up keeping the probe holes lined up.
I love mine, I have 25' of Excel class A double wall insulated. I have (2) 45's on a short section, that I'm going to remove this year and clean outside. Last year the Soot Eater made it through the (2) 45's OK, but it's beating the heck out of my fiberglass rods, so I'm going to do them separately. Does anyone have any suggestions/tips for keeping the dust contained, while I'm cleaning the tall chimney?
