There are many who go on and on about 'pumping away' like it's the third rail of hydronics system design decisions. Yes there are many circumstances where you can create big problems by teeing in the expansion tank after a pump, but the wood-boiler-to-storage loop is not one of them; assuming a small flat-curve pump, fat pipes, and short distances to storage.dogwood said:I would like to know what you think about the location of the expansion tank/air separator/make up water supply relative to the Termovar Loading Unit (which contains the primary circ pump) in this diagram. What confuses me is the pump is on the return rather than the supply side, but the expansion tank/air separator are on the supply side of the boiler. Is this less than optimal, acceptable, or just messed up.
You can pretty much rely on the Tarm reference designs to be nicely detailed and valid, although there are often ways they could be enhanced or simplified to suit a specific situation.
Amtrol advises taking the line to an expansion tank down and downhill from where it tees into the system so air can't migrate and accumulate under the bladder membrane.
