Europa 75 filling with smoke
Andrewkarlin
1
Vermont
Hello, I recently moved into a home with a Europa 75. It was a foreclosure so it Hadn’t been used for a couple years. I’m using wood pellets in it, and I’ve made sure that their dry. The first time I ran it it was earlier in fall and I just wanted to see if it worked properly after I cleaned it per what the inspector told me. It’s getting colder now and I went to use it and the past few times I’ve started it it’s went through the A1 and the A2 perfectly fine. As soon as it stops A2 and starts to run, it fills full of smoke and puts out the flame. I can turn it off and on the C2 code cycle it will eventually clear it out. I can’t seem to find the problem, anything helps. Thank you
