BeGreen said:I'm wondering if at some point a less than fine abrasive was used on the glass? It sounds like it might be over-cleaned and scratched. If so, the best solution would be to replace the ceramic glass and be careful what is used to clean the glass.
billjustbill said:I have Lopi's "Freedom Bay", and I got the glass etched with the "Ducks and Pond" scene.
(broken link removed to http://www.lopistoves.com/productuide/detail.aspx?id=218)
In the website's Pamplet Info, all they show now is a landscape with a big Buck in the center. This fireplace insert originally came with a clear glass, so the etched scene was an extra cost and usually at the full factory suggested price.... What some buyers don't realize, is that the dealer will keep the original glass for their Parts Department if you don't know to ask for it....
The etching for Lopi's scene is on the outside, so the glass will usually burn clean with a good hot fire and the light gray wipes away easily as others have said. After cooling, cleaning of the smooth side of the glass with a 15 minute soaking spray of oven cleaner on the cooled-down glass is quick and easy if you should have Visitors coming.... It is a bit messy if you don't put newspapers under the door while cleaning, but it does get it clean only because the inside glass surface is so smooth.
Maybe a quick email to the Maker of your stove will help you find out if the glass was accidently installed backwards. To get it "Polished-Out", you would have to remove the glass. You'd never get it done evenly leaving it installed while the pad and compound is bumping up against the holding tabs and insulation gasket around the glass.
If you learn it is installed backward, after you hear from the Maker and clean out your stove, I'd call the store you bought from first. Then take the door off and take it back if they won't come back for a free Service Visit. I'd let them do all the work of changing it around...and request a new glass panel if they can't get it clean.
Please let the Forum know how it works out.
billjustbill said:Just out of curiosity, how old is your glass and stove?
Could be..I never had that haze till I tried the ash water deal.savageactor7 said:A slight white haze on the glass can be the remains of hard water. Fortunately we were warned about that and only use bottled water with a paper towel to clean the glass.
In the website's Pamplet Info, all they show now is a landscape with a big Buck in the center. .
You might check with Scan tech support and see it this stove uses IR coated glass, some do. If this is Robax IR, the coating is only on one side of the glass.
If you have new glass, I suggest using nothing but moistened paper towel with ash from here on out. I've used that for many years on both pellet and wood stoves and never had any etching or scratching.
That could be. I'll ask them. Although, they don't have any tech-support. You have to pretty much contact
Jotul. But, Jotul is pretty good at answering back.
I did see that glass, while doing some research. But, at the same time,
I also found out that certain stoves are very prone to etching, just by the way their designed...
I'm pretty sure that my replacement glass is not IR coated. It's EuroKera Pyroceramic. So, hopefully, it will not etch...
Sounds good. I hadn't heard of EuroKera before. Looks like they make three versions of their pyroceram product. The regular product is uncoated. Stayclear (Everclear+) is coated.
(broken link removed to http://www.eurokera.com/products/heating/heating.html#)
I put my ohm meter on the old/original piece of glass from Scan. I tested both continuity and ohms on both sides. No current. So, it probably was not coated.
If you've ever owned aluminum window screens, instead of the cheap fiberglass/plastic screens they make today, you may have seen a similar thing when the aluminum oxide begins to plate up on the glass after a few years. Happens fairly rapidly if you leave your screens in year-round. I wonder if something like that could be happening, such as platings from the metal components in the stove or fasteners in your wood (pallets? framing lumber?) plating onto the glass at high temperatures.
What would you expect to find with an ohm meter? Anti-reflective coatings work by transforming ("matching") the wave impedances of two media (namely air to glass), in which you have a high index change, but most are dielectrics / not conductive.
Interesting thread.
Can I ask how much the replacement glass was?
