Manatarms said:Wow! Thanks for all of the responses!
Rich L, I've read a few comments in the forums that the Equinox will not obtain extended burn times without the use of a pipe damper. My other concern with soapstone is that I might accidentally over fire it. Some on the forums have suggested that the EQ can’t crank out the same heat as a steel stove because of the 600 degrees max temp restriction. I’ve also read that when asking the EQ to crank out some serious heat the wood consumption is pretty high (especially without the pipe damper) in comparison to other stoves.
Obviously these comments are anecdotal, but it’s got me thinking. Nobody seems to make ANY negative comments about the BKK..other than the looks. I’ve also read that the BKK is easy to keep adjusted and will get only equally well just cruising or cranking.
Does anyone have anything negative to say about the BKK?
-mark
I don't use a pipe damper with my Eq. and get some good burn times........not 15 hours of fire but warm rock and there will be enough coals in there to relight with some small sticks. I am under the impression that you only want a pipe damper if your draft is exceptional.
You can expect 6 hours of real good heat then 2-4 hours of big coal bed slowly burning off and if left alone the rocks are still warm to the touch and throwing some heat for another 2 or so hours. Up to maybe mid November and from March on expect 2 feedings a day, mid winter requires 1 full load in morning, another at 5 in the afternoon and a good stuffing before bed at 11. On real cold days and nights, don't be afraid to turn up the heat, it's a big stove and 120k btu's/hour is an enormous amount of heat, I expect I have my 2500sf up to temp well before the stove is running at full output.
I'll bet the BKK will heat in mid winter with 2 loadings per day.........nice kitty.
The hearthstone is a looker, i'll say that!
We just bought some new chairs..........the Raymore and Flannigan copies were less than 1/4 the price of Stickley chairs, my wife didn't like the looks of the cheap copies but I would have had them. She was right and we love our new chairs, someday our kids will like them too! I can't wait to sit in our new rocker in front if the stove.
