Proof of nearly burning down the house, then installing a bogus fix that now only soots the crap out of it? Carl's performance appears to be measured by timebomb ticks.
house burnt be4 gcan. 6 yrs since with no prob,seemingly. stochiometry of woodburn neednt involve keeping a clean glass for efficiency.BeGreen said:Proof of nearly burning down the house, then installing a bogus fix that now only soots the crap out of it? Carl's performance appears to be measured by timebomb ticks.
smwilliamson said:If Carl wants to install a trash can on his own exhaust, fine. Somewhere you cross a line when you do it for others, whereas you are somewhat responsible for the result. In this situation the result wasn't a fire (not yet) but exhaust leaking back into the house. There was a mess and the homeowners sought outside professional help to resolve it. In clear conscience when I leave a job the work I do needs meet or exceed some kind of universal code of acceptance, if either by a professional or licensing standard, etc...
Just because there hasn't been a fire in 6 years should not exclude that it was ever acceptable to have one in the first place.
Shorty said:smwilliamson said:If Carl wants to install a trash can on his own exhaust, fine. Somewhere you cross a line when you do it for others, whereas you are somewhat responsible for the result. In this situation the result wasn't a fire (not yet) but exhaust leaking back into the house. There was a mess and the homeowners sought outside professional help to resolve it. In clear conscience when I leave a job the work I do needs meet or exceed some kind of universal code of acceptance, if either by a professional or licensing standard, etc...
My problem isn't what he did. Its what he did as an installer. Clearly not code and potentially a fire and CO2 hazard. When you do seek a professional that is what you should get a professional.
~*~vvv~*~ said:house burnt be4 gcan. 6 yrs since with no prob,seemingly. stochiometry of woodburn neednt involve keeping a clean glass for efficiency.BeGreen said:Proof of nearly burning down the house, then installing a bogus fix that now only soots the crap out of it? Carl's performance appears to be measured by timebomb ticks.
read the OP which mentions glass wont stay clean & can was added to avert the fire issue. pstove smoke in house stinx i know as well as embers can fly out a horizontal pipe & peeps get concerned over possible fire as a result. carl found a solution [1/2 assed maybe} which noone else of whatever status thought of. Now carl gets condemned because of acceptable standards regardless of shortcomings such as exhausting embers ALLOWED BY CODE & DISMISSED BY "AINT GONNA RESULT IN A FIRE". soot on siding has been mentioned previously & a similar UL tested system is being sought. i know its not code but codes change & 6yrs is proof pudding 2me, moreso than 1day UL testing? A pro cant do this due to liability but can nitpick criticism rather than find the positive aspect, why?WoodPorn said:~*~vvv~*~ said:house burnt be4 gcan. 6 yrs since with no prob,seemingly. stochiometry of woodburn neednt involve keeping a clean glass for efficiency.BeGreen said:Proof of nearly burning down the house, then installing a bogus fix that now only soots the crap out of it? Carl's performance appears to be measured by timebomb ticks.
Pook... did you eat paint chips as a kid?? Whether or not it worked for 6 years, it is a HACK JOB ....and just outright carelessnes, what do you think would happen if the couple brought in an inspector or fire marshall....
SM, I had my stove prof.installed last year. When I called around for quotes (I forget exaxctly what shop it was) His name actually came up more than once. In light of this.... I'm glad he was not the one that did the install.
~*~vvv~*~ said:See! carl invented something? Code books dont define science, its the other way around- something the local hubris seems to not understand but rather uses to stroke the ego. i understaND PROF LIABILITY & INDUSTRY standards & a robot would be more reliable than a human when it comes to following directions. Fortunately, the universe no longer revolves around the earth, or does it?
gotta ask= who's footing the bill for the up to code alteration? homeowner or gov.
it is! otherwize solar heaters wouldnt workfirewarrior820 said:~*~vvv~*~ said:See! carl invented something? Code books dont define science, its the other way around- something the local hubris seems to not understand but rather uses to stroke the ego. i understaND PROF LIABILITY & INDUSTRY standards & a robot would be more reliable than a human when it comes to following directions. Fortunately, the universe no longer revolves around the earth, or does it?
I bet you think the sky is green Δ
~*~vvv~*~ said:http://en.wikipedia.org/wiki/Spark_arrestor
considering how much excess combustion air pstoves have [xcept Europa} i'd not assume inefficient combustion without analyzing the exhaust & obviously the can isnt totally sealedWoodPorn said:~*~vvv~*~ said:http://en.wikipedia.org/wiki/Spark_arrestor
A spark arrestor is a device intended to prevent combustible materials, usually sparks or other tiny flaming debris, from escaping into areas where they might start fires.
They are most commonly used in conjunction with motor vehicles (inserted into the muffler), as well as improving safety within fireplaces, and various electrical equipment. Often, a spark arrestor mimics a net fashioned from tightly interwoven wire gauze built to resist bits of ash, sparks or other such dangers.
Your attempt to bring light to our feeble minds has failed, the above highlighted text implies there is a way out for the "spark carrying captured gasses" a lidded, sealed shut, 20 gallon garbage can with a pipe stuck into it does not make a spark arrestor, just a place to restrict exhaust and cause inefficent combustion (stochiometrically speaking of course)
WoodPorn said:(stochiometrically speaking of course)
~*~vvv~*~ said:i'd not assume inefficient combustion without analyzing the exhaust & obviously the can isnt totally sealed
Your 2 easy 2 figure out I knew what your answer would be that why I put it out there ,,,simple~*~vvv~*~ said:it is! otherwize solar heaters wouldnt workfirewarrior820 said:~*~vvv~*~ said:See! carl invented something? Code books dont define science, its the other way around- something the local hubris seems to not understand but rather uses to stroke the ego. i understaND PROF LIABILITY & INDUSTRY standards & a robot would be more reliable than a human when it comes to following directions. Fortunately, the universe no longer revolves around the earth, or does it?
why does my 25 & others? have a built in airwash system for the glass.j-takeman said:~*~vvv~*~ said:i'd not assume inefficient combustion without analyzing the exhaust & obviously the can isnt totally sealed
Black stuff stuck on glass is over rich condition. No?............![]()
~*~vvv~*~ said:why does my 25 & others? have a built in airwash system for the glass.j-takeman said:~*~vvv~*~ said:i'd not assume inefficient combustion without analyzing the exhaust & obviously the can isnt totally sealed
gcan may need holes,dunno, but do know the direction & speed of the wind can have a similar pressurizing effect unless its a 10-2-3 setupj-takeman said:Pook, Are you really Carl? or is he just your new idle?
Carl did not invent the spark bucket. A Meir copy cat. The spark bucket has been around for a long time. And the bucket needs a vent to work properly. So he didn't even get that right. But I will give him the resourcefulness award, That would be a fire extinguisher.
& u dont need a blockplate @ the bottom of ur chimni! :roll:Xena said:Carl is a dumb azz and the places that outsource him to
do stove work are hurting their reputation big time.
