Although not EPA certified the original Resolute was a decent small heater with a basic secondary burn system. We loved ours.
It is a gorgeous little stove and built like a tank.
![Cool :cool: :cool:](/talk/styles/default/xenforo/smileys/shade_smile.gif)
I played with that 'horizontal burn' thing a bit at my BIL's but never ran the stove and watched the stack enough to figure out if it actually did anything. From the manual, I understand it was an early attempt to make the stove a bit cleaner. Could you tell a difference? How did you run it?
I wish I could afford a newer one....By the way,thank you for your support.
My writing style can be a bit over-dramatic when I'm trying to get a point across. I was just trying to lay out the advantages of the new re-burn stoves in case you weren't aware of them. Hopefully it wasn't taken the wrong way. I burned an old Englander 24 for years. It was a cigar-burn, step-top, radiant plate-steel stove. It also had an early attempt at a cleaner burn, with a steel plate in the top/rear of the box that was supposed to circulate the smoke back to the fire for more complete burning. Since that was before I got "dry-wood religion," I was smokin' out the 'hood trying to burn dead Read Oak that had only been stacked 3-6 months. Uhhhh, no, not dry yet. I got the Dutchwest used for 300 bucks but didn't know much about cat stoves, didn't even know about tube stoves, just thought there had to be something better. Pretty much the same results (cold house in the morning) until I started getting my wood drier. We have no backup heat so I've stuck with the cat stoves for the long burns that can still have this leaky old house warm half a day later. There are a lot of people burning the old stoves with wet wood, and don't know there's a better way (I was one.)
![embarrassed ;em ;em](/talk/styles/default/xenforo/smileys/embarrassed.gif)
It sounds like you and the old puffin' man know what you are doing. I don't begrudge anyone running whatever stove they want; Like puffer said, it's legal after all. We just need some way to get the word out so everyone is burning as clean as possible, no matter
what stove they run.
Hey, another advantage to the new stoves is they have a
window! It's a lot harder without one to tell what the stove is doing, and I like seeing the fire, too. I couldn't go back to no window now, it would be like trying to drive with a blindfold on.
![shuteye <> <>](/talk/styles/default/xenforo/smileys/shuteye.gif)
I figured it was pointless to replace the windows on the Resolute, since they probably get blacked over quick, so just left the steel covers in place.
As I said, you can upgrade your stove for pretty cheap, maybe for nothing if you buy used, since you can get some money for the old VC stoves. My SIL got her Fireview for 350, and BIL got that old Resolute III for 300. Granted, the Fireview had been over-fired (she didn't consult me before buying, but she's an artist and liked the look of it.) The owners had just moved in, and wanted the stove gone. Luckily, I was able to get the stove running decently without a lot of cash outlay (Woodstock parts are
cheap!)
