I'm happy to report that gasifiers don't NEED storage....it's nice, but c'mon you can achieve a clean burn w/o storage...it just requires you to think a little bit when loading....similar to how you would tend a wood stove.  It works for us anyway.
			Beno said:1. Based on the code in my area, I need ventilation to each room if I don't have a furnace with air ducts. If I have a furnace, the ventilation will be done by the furnace fan to the rooms, and I'll have to supply outside air to the furnace. So, even with hydronic heating I need to install ducts (smaller) for ventilation. Cleaning them may be harder than with the furnace ducts.
Beno said:2. I thought that the wood boiler comparing in efficiency with a Caddy EPA wood furnace has to be a gasification boiler. Can you please recommend a very efficient (non-gasification) wood boiler?
Beno said:9.32.3.7. Ventilation Systems Not Coupled with Forced Air Heating Systems
(1) This Article applies to a mechanical ventilation system in a dwelling unit that,
(a) does not contains a forced air heating system, or
(b) contains a forced air heating system and the forced air heating system is not used for circulation of the ventilation air.
(2) The mechanical ventilation system shall introduce air to and circulate air throughout the dwelling unit in compliance with this Article.
(3) The mechanical system in this Article shall include a heat recovery ventilator installed in accordance with Article 9.32.3.11.
(4) Outdoor air shall be distributed by a ductwork system from the heat recovery ventilator required in Sentence (3) to each bedroom, to any storey without a bedroom and, if there is no storey without a bedroom, to the principal living area.
This is for Ontario, Canada.
Beno said:1. Can you please recommend an efficient wood boiler for my location: Ontario, Canada ?
Beno said:2. Can I use instead of the large water tank an indirect like this?
http://www.heatexchangersonline.com/indirectwaterheater.htm
http://www.thermomax.com/tkindex.htm
Eric Johnson said:When I bought my boiler, about six months ago, the EKO had the best price. But like the Tarm, it's an import, so the weakening dollar has driven up prices recently. For regular gasifiers (Tarm, EKO, Wood Gun, Econoburn), I'd be willing to bet that Wood Gun is still at the high end and EKO at the low end, with Tarm and Econoburn probably pretty close to each other in the center. Just a guess. As to true value, everybody's got an opinion, many of which are regularly expressed in threads on this forum.
EDIT: I forgot the BioMax, another import. I believe they're a bit cheaper than EKOs, possibly with more features.
