saydinli
Burning Hunk
Is N/S loading an option on the Lopi 1250?
That would help make sure all of the wood is burned through properly.
If you are gone a long time during the day, that's where a BK or VC thermostat would come in handy. With my small firebox, I need to get the coals burned down for more room to load wood. The ash grate helps make more room as well..Toward the end of the burn the flue cools down and the draft weakens ,thus the need to open up the air to burn down the coals ,or reload.
I think you would need some pretty short splits, from what I saw at the stove shop..Is N/S loading an option on the Lopi 1250? That would help make sure all of the wood is burned through properly.
Depends how long your splits are. I cut my wood 13" and load my 1250 N-S.No, the stove is set up E-W front load only.
Hello all
I'm not sure if this is related but I have a
hearthstone heritage EPA stove just installed .
The stove will not burn unless the door or ash pan door is open.
I do not get any smoke in the house
Wood is very dry
I do start a hot fire before trying to close the door ( drafting great)
With a cold stove I put a blower to the air intake. Trying to clean it out. The control on the front was functioning.
I had an old stove hooked up last winter with no problems. But it wasn't an air tight stove.
Starving for air. It doesn't seem like a flu problem.
Help
Was it actually kiln dried or just run through a kiln to kill off bugs making it legal to transport? Most of the "kiln dried" stuff is not really dry you need a moisture meter to know for sureOk fuel is crossed off the list.
I bought some Kiln-dried and it still only burns with the door cracked.
I can see the secondary burn going on at the top of the stove.
So some air is coming in.
OK
Here is the update.
Using kiln-dried wood ( yes dried not just bug killed). I could close the door once I had a good bed of coals But with the stove on high it was running like it was on low. Secondary burn was working but very little flame near the wood. Temp on top of the stove was 500F.
Today i tried with 2x4s same result.
Im going to see how to take apart the bottom of the stove and take a look.
sodbuster what is N/S
OK
Here is the update.
Most stoves will burn like crap if they don't have a layer of ash on the bottom. It would be an easy solution if you just need a few fires to build up some ash.Hello all
