j7art2
I'm burning almost 100% hardwood extensively this year. I just take offense to the 'says the guy burning green wood' comment, assuming I'm not a responsible burner. I use a moisture meter, and this is my first year burning wood in my own house, so I'm making due with what I've got, but I've done a darn good job checking what I have and separating it. I grew up on wood heat and always seasoned for 2 years C/S/S growing up. I'm well versed in good wood burning practices. Considering the amount of wood I've burned, if I had poor wood burning practices, I'd have had a chimney fire or four by now, and why I specifically offered to show a pic of my chimney to prove it.
I guess this is neither here nor there, but I've narrowed my extremely high wood consumption to a few factors:
1.) I didn't have a fresh air intake installed in my basement. Wood like to smolder without it, making me put more wood on to cause it to "catch". Immediately the problem remedied itself once I installed one and my wood usage has been cut significantly since.
2.) I have a HUGE firebox. I am 6', and 215lbs, and if I could fit through the door, I could literally fit inside my firebox. It's 28" deep and probably close to 40" high. This leads to problem #3.
3.) My entire large firebox is completely uninsulated steel. The only place for firebrick are on the sides. It has a very poorly designed V shaped bottom, and each piece fits 5(?) pieces of firebrick. No insulation on the sides, none on the back, none on the ceiling. Essentially, I'm losing half my heat due to poor insulation. There is no way to install firebrick along the sides or back, which results in #4.
4.) My basement is completely uninsulated cinderblock, and my wood furnace is in the corner. The walls are cold to the touch, and it is actually a bit chilly in the basement with the fresh air intake installed. My unit gives off virtually no radiant heat unless I'm burning close to the overburn mark on my flue thermometer. I don't know if this is because the basement walls suck it out or what.
This makes me wonder if getting a Drolet Tundra will even work for me. It heats 2500 sqft, but the house is 1700sqft, and the basement is probably 600-700. The last thing I need is to install another unit that struggles to keep up. If I wanted that, I'd just keep what I already have.
