B-MoreDan, this post by NotGoodAtScreenNames has been really helpful for me: https://www.hearth.com/talk/threads/stove-selection-and-location.161797/page-5#post-2203353
I apologize if I am not posting correctly but I am looking for some help removing the left shroud/ fan housing on an enviro Kodiak 1700, any help would be appreciated. Also suggestions where to buy a replacement, local AD is not an option and others in my area won’t touch anything they didn’t sellI just bought an Enviro Boston 1700. It’s my first wood stove, so I am a complete newbie. Despite being new to wood stoves, our wood stove experiment has been going well so far, due to the help we’ve received on this forum.
While I was researching different stoves, I found several running threads on specific stoves that I found to be really helpful. I would like to start a similar thread with information specific to Enviro Kodiak and Boston wood stoves (as well as other Enviro stoves, I’m not sure how many models there are?). Hopefully it can be a helpful resource to all of the Enviro owners on hearth.com, as well as to prospective buyers of Enviro stoves.
It doesn’t seem like Enviro stoves are as common as BK’s, PE’s, Jotuls, etc, but hopefully there are enough to support a dedicated forum thread. Who knows, maybe this thread will result in the Enviro tribe increasing!
A few questions for you experienced Enviro burners:
- How many square feet are you heating?
- How many years have you had your stove?
- Have you had to replace any parts?
- What is your typical maintenance routine for your stove/chimney?
Hey everyone- the blowers are set up diff between the Boston and the Kodiak. For the Kodiak, take the surround off, pull out the left side a bit, find the two t20 screws that hold the blower pod on, just loosen (they have holes for accessing them) and remove the pod. I've found the blowers to be quite good to stay clean being mounted vertically. The boston needs the top plate (3/8 inch wrench needed to loosen the bolts), take that plate off, then the door and then the side panels are accessible. I only tighten down the front bolts on the sides and one bolt on the top plate. Boston owners will see what I mean. Its not easy, but it hides everything. The Venice and Kodiak also have one top bolt on the pod to remove to take their blowers off. Hope this helps.
Stovelark, thanks this this info...I have a 1700 but it appears to be an older model, by that I mean 8-10 years. My version has a shroud with diamond shaped cut outs backed by a wire screen for the intake (both sides) and are at 45 degree angle from the surround to the front of the unit. On the left shroud is a 3 way toggle and a dimmer switch, Both of which are broken, but the unit is still running as one of the positions is still functioning. I tried what you mentioned above but still can’t seem to get the left shroud off, am I overlooking something?Hey everyone- the blowers are set up diff between the Boston and the Kodiak. For the Kodiak, take the surround off, pull out the left side a bit, find the two t20 screws that hold the blower pod on, just loosen (they have holes for accessing them) and remove the pod. I've found the blowers to be quite good to stay clean being mounted vertically. The boston needs the top plate (3/8 inch wrench needed to loosen the bolts), take that plate off, then the door and then the side panels are accessible. I only tighten down the front bolts on the sides and one bolt on the top plate. Boston owners will see what I mean. Its not easy, but it hides everything. The Venice and Kodiak also have one top bolt on the pod to remove to take their blowers off. Hope this helps.
Thank you very much stovelark, will give it a go todayOk your stove is about the same age as mine circa 2008-2009. If you take off the surround (two screws behind it), and pull the insert out a bit on the left side facing, look back on the pod. You'll see two holes cut out. Inside those holes two t20 torx screws are loosened, along with the small 5/17 screw on top of the pod. The blower can then be taken off of the body of the stove. The switch at the base of the pod is the auto/off/manual blower selection and you have the rheostat for the speed of the blower. I liked this earlier version of the Kodiak better too (the diamond style sides). Hope this helps. If not, go to enviro's website and look at the older manual on there, if you don't have a manual. I do believe it shows these screws too.
A little thread bump here.
It’s really friggin cold for most of us. How are the Enviros holding up for you?
My routine has been a big load N/S on a relight in the morning with a few coals around 7:00 AM. Another load E/W at about 4:00pm. Still a lot coals so I push most of them towards the back and load in front. Then before bed I’ll still have a good amount of coals. More than I would normally reload on, so again a few splits E/W in front to keep it going through the night.
House has been warm, oils kicks on a few times a day at the end of the cycles but I’m not trying to be a wood purist. Still at only using 1/2 tank all year (including the last few weeks for hot water). So I’d say the Boston 1700 is doing all we could ask of it.
How about you?
![[Hearth.com] Enviro Wood Stoves [Hearth.com] Enviro Wood Stoves](https://www.hearth.com/talk/data/attachments/219/219457-ab7ba99af41a4db68301286f0af4342f.jpg?hash=Oh0CaUcZMd)
FYI: while my stove was down I cleaned out my blower.
Anybody ever have any luck with getting I touch with Enviro customer service?
I have a potential warranty claim that I would like to pursue, but it looks like you need to go through a dealer. The dealer I bought the stove through closed a couple years ago. I called another local dealer who said they should be able to help me for a $35 fee.
