I continued to be impressed by all the great advice here.
My Enviro dealer was bright-green-new at pellet stoves at the time, this was the first pellet stove he'd installed, although for years he'd installed LOTS of stick and gas burners, and thought it might be a good thing to get in on "this pellet fad". The guy really is a pro at installs and sweeping chimneys, I can't fault him. He was extremely conscientious about my install, even though I was well within clearances, he still checked everything thoroughly.
Our original installation for the old Austroflamm was primo: big wide pipe (it's 4" or bigger but I don't recall the exact size) all the way up to the windproof cap, 30' up. Big cleanout tee at the bottom with an adapter for the stove coming off that. We have a good standing draft: if you have the stove disconnected, you can fell the air moving up the chimney. The original fireplace had an OAK so we were just fine there.
Just to throw gas on this fire... With the expertise in creating and programming control panels we have nowadays, you'd have thought that
somebody should have figured out that if you push for 5, it ought to run at 5 for about ten minutes and then drop down to 3 and lock out any change to a higher level for a few minutes until the box cools off. Compare that with 20 years ago, the Integra would hold a high fan speed for a good long while after you had it set to FULL HIGH and turned it down.
I'm going to wait a couple more years (and put in probably a couple more motors in the meantime) and see if Rika gets us a local dealer. If this Empress fails altogether (which I don't put out of the picture) then according to you guys, the Harman is a nice quiet stove? Good quality? I looked at a Breckwell during my research and was very much not impressed with build quality. Saw a Quadrafire, asked to see it start, and saw smoke coming from it into the room. Hmmm. Visible Smoke = Potential Carbon Monoxide leaks...
