Ya I I will let ya know..Its driving me nuts to...to bad because the stove seems in great shape otherwiseWhatever it turns out being you have to promos to let me know what it turned out being . it's driving me nuts lol
Picked up a multi meter tonight after work...what do I have to set that at to check the timer module as I never used one before...and which 4 pins across the bottom of the timer module do I check...thanks for any help need to get this running soon[/quote
Sorry I'm at worg now but I will check when I get home in morning . 4 now you can look on YouTube to learn how to use that meter
hello, i tested it on ACV 200 on the multi meter and when i pushed start the numbers went all over the place for a split second and then right after that while it was running it was at 01.0 and on the 500 setting it was at 001Did you test it ??? It shows how on page 8 and 9 on the manual don posted
thats 1 volthello, i tested it on ACV 200 on the multi meter and when i pushed start the numbers went all over the place for a split second and then right after that while it was running it was at 01.0 and on the 500 setting it was at 001
numbers jumped up when first hit start button,but they were steady at 1 volt when it was running after thatSo when you tested that timer you got 1 volt ???? Was it steady or pulsing ??
Wow that's a good price .. Are you sure it is the bottom blue box ???? bottom 1 is a 15 min timer for the exhaust fan ... The top one is a the auger timerLooking like it's a faulty auger motor timer, the blue rectangle box mounted to the lower right rear corner of the ef3.
I got one for $33.50 + shipping last March. http://www.kleen-ritecorp.com/p-35659-infitec-time-delay-relay.aspx
That's the one they list on their website but I had them send me the 2-second timer instead; it maintains a more consistent flame. Their P/N 138629JS, description TRS51A31S2 PELLET STOVE TIMER 2 X 2.
