Welcome to the forum
We will need a whole lot more information
Does it feed pellets?
does it light the pellets?
does the combustion fan come on?
Not doing anything, when you plug it in the control panel will light up for a few seconds, then it goes dark and no response from any buttonWelcome to the forum
Do you think control board is bad?Not doing anything, when you plug it in the control panel will light up for a few seconds, then it goes dark and no response from any button
The wiring looks good, fuse is good and to be sure I bypassed the vacuum switches with no responseIt is possible the magic smoke left the board!
hopefully, someone with more Englander experience
will chime in
Do you have a manual? if not here is one
Check the wiring, and all plugs may be a loose or dirty connection
Bad fuse?
Try swapping your fuse out.. on mine I temporarily bypassed mine to check this and that was my problem.. fuse was still good but was not connecting right.. I actually ended up going with an old school ceramic fuse and it's worked fine now for yearsThe wiring looks good, fuse is good and to be sure I bypassed the vacuum switches with no response
