Englander pdvc 25
tigerchef1969
2
Ohio
Hope someone can help me with this problem. I have had some problems with the stove burning too hot, flame too high. I thoroughly took the pellets out of the hopper, made sure there was no blockage and totally took everything out of the stove itself and cleaned it really well. Now the problem seems to be the right side of the stove seems to be blowing cool air and the left side is hot on the convection blower.
Is the impigement plate positioned correctly?
Except a lazy flame from lack of oxygen isnt going to make the stove run hot. I am betting a change in pellets being short hotties or mis adjusted lower fuel/air settings...
But since the stove was just cleaned and now cooler air coming from the right side is why i say the impigement plate may be out of position.. but regardless the air from the right side will be cooler than the left.
Info on your set up would sure help us to help you. HOW LONG IS THE EXHAUST PIPING? DO YOU HAVE AN "OAK" ? HEAT RANGE NUMBER ? BLOWER SETTING NUMBER ? THE THREE BOTTOM NUMBERS ? Would be lots of help to every one here .
