Thanks for putting this up here. It helped me a lot since i'm a new stove owner.
Regards,
Liza
Placement financier
Regards,
Liza
Placement financier
NEStoveOwner said:No gasket between the gear box halves and shaft end is exposed. Id say its a MK.
Mike, did you every pass the GA info on to the lab guys at Englander to do a comparison?
That was your last PM to me in Jan 2009. Sorry if you posted the results and I missed it.
donbryce said:NEStoveOwner said:Just checking in again. GA Auger motor running fine and stove is not having any issues. No work done with Englander to investigate my motor failures. Have not heard back if they are going to test GA units themselves.
I've been following your threads, and if I may, please comment on the following summary, which I believe captures the 4 available auger motors mentioned in your posts which will work without modification on the Englander 25-PDVC and PDV:
MFG........................Part#..........................On-line sales....................Price.......URL
Merkle Korff............U-047040................Englander........................$130.98 .... http://tinyurl.com/dmom2p
Merkle Korff............8211.......................Merkle Korff......................$73.18 .... http://tinyurl.com/averwq
Dayton...................1LNG2A...................Grainger...........................$89.00 .... http://tinyurl.com/cftraf
Gleason Avery........A901.......................Gleason Avery...................$79.95 .... http://tinyurl.com/cbc9ze
I assume that you're happy with the A901 and would recommend it over the others. I couldn't find the part number on the MK (model 4515UI-050) in my 25-PDVC on their website, so assume that it's assigned to the 'custom' motor supplied to Englander.
Here are a few Q's:
(1) Is the MK U-047040 identical to the MK 8211, or does the rotation need to be changed, or the output shaft modified to fit the auger?
(2) I re-read your posts and cannot find where I swear you noted that one of these motors was available at a reduced price for the motor portion only, that is, without gearbox...was that the Dayton?
(3) Are any of/all of these motors easily fitted to the gearbox on the MK motor in the Englander?
Bottom line here is that it would seem from everything I've read that the gearboxes on the Englander MK motors are bulletproof, but the motor portion is not, so the best cost effective solution to a failed auger motor would be attaching a GA A901 motor to the MK gearbox supplied with the stove, no?
And the cheapest would be fitting whatever of these is available without the gearbox to the MK/Englander gearbox?
EDIT Feb.25/2009: I emailed Grainger, and the Dayton 1LNG2 motor is not available as a separate part. Also got a reply from Merkle Korff re. availability of motor only for their 8211, and it is also not sold separate.
edwinjk said:Hey Guys:
I am a newbe. I have an Englander 25PDV pellett stove. When I shut down, I clean it with
my shop vac. Then I take WD40 & spray it in the auger. This does a couple of things, first it
lubricates the auger & prevents it from binding. Also, I noticed that it seems to disolve some of
the carbon. The excess WD40 will burn off. I clean my stove once a day & it seems to work.
I am using Kentucky Kernel hardwood pellets with a low amount of fines. Just thoyght that I would pass it on.
edwinjk
birdman Jack said:I am not having a problem yet but I am quite sure I will before long. The top motor for the hopper runs cool but the bottom auger runs to hot to touch. It is because it is hooked to the augar that is feeding the fire so it is exposed to the heat. I have been looking for a replacement motor but but cannot believe the price of these units. I am thinking of trying to find 12 volt motors to replace them. Anyone have any thoughts about this?
packrat35 said:The new Gleason-Avery gearmotor is working very well. Actually it is working a little too well.
The gear motor that was in there before was rated for 1 RPM and the new motor is rated 1.1 RPM. I thought 0.1 RPM would not make much of a difference but it seems to.
The Gloking pellet stove I have has 4 pellet feed settings and then a potentiometer that gives the ability for a slight adjustment on each setting.
These are the settings Low, Medium, High, and Max/High
Now with this new gearmotor the low setting is more like the old medium setting and the medium setting is like the old high setting.
Is there any easy way to slow these motors down?
tflight said:Great thread... my auger motor on an old Breckwell P23 just died so this has been very helpful. My motor is a 1.0 RMP. I'm likely going to replace the stove when the heating season ends so I'm not looking to throw a ton of money into it nor am I worried about the fix lasting several years. I've looked at these four options:
• Breckwell lists this $144 + shipping replacement model which is close, but not exact to what mine looks like. (But is the correct replacement model.)
• It looks like Gleason Avery only has down to 1.2 RMP models and with only four feed settings on my stove I don't want to give each of those settings a 20% increase.
• Grainger has this $90 model with a fan which is interesting... I don't know if that big fan would add much noise or not. Also Grainger is wholesale only and requires a business ID.
• Finally there is this MK model for $73 that looks like it would work.
Any opinions or other options/sources known?
