Going to install a homemade Outside Air Kit on the basement 30NC. At first glance I thought it would be an easy straight forward job. But upon closer inspection, I noticed that besides the typical 3 inch circular inlet hole at the back of this stove, there is an additional small rectangular hole directly above the 3" hole.
I understand the one hole is for primary and the other for secondary air?? Or something like that.![Confused :confused: :confused:](/talk/styles/default/xenforo/smileys/confused.gif)
My question is : While fabricating an OAK, should I include BOTH holes in the external piping or just the 3" hole. I figured out a way to make a connector that would feed the square hole down into the round pipe and then to the outside. Is all that necessary though?
I am trying to avoid the air handler from drawing combustion gases out of the stove at the low end of the burn cycle when the flue draft becomes less. Also, the stove is in the same room as the clothes dryer.
Basically , looking to stop the affect of negative pressure caused by room fans.
So, whats the deal with those TWO holes in the Englander?
