Hi everyone! Now that the weather has been getting colder and draft has been getting better I've been getting a kick out of all the "did I over-fire my stove?" threads. I figured its time to ask a question.
My Englander 30 with 22 feet of stove and chimney pipe wants to run pretty hot. On a reload or even after a fresh start the temps will normally get up to about 750 before settling in. I only leave the door cracked for a moment (if needed) and dial down the air intake in increments as soon as I can. I usually can't get away with completely closing the intake but I'd say I leave it an 1/8 or 1/4 inch open. When the secondaries kick in the 30 becomes a box of hellfire! That's when the temps start climbing. 750 stove top and 800 stack temp is very common.
At this point I'll usually turn the blower on for fear of the stove getting even hotter and the stove will idle like this for another hour or two and start slowly decreasing its temps.
The only reason I'm complaining is because 750 degrees with the blower on makes the house too damn hot I must be doing something wrong because I read that most people get their fire going and the stove idles at 500-550 for hours before cooling. That would be ideal for me. Plus I think I'm going through wood much faster at 750 than I would be with a stove temp of 550.
What am I doing wrong? If I try to close the intake sooner I always end up smoldering the fire an get tons of smoke. The excessive heat really isn't a problem, just too much of a good thing. What worries me is if I have a brainfart and forget about the stove for a minute before completely dialing it down....that it would go nuclear and I'd be one of those people asking if I overcooked my stove!
Your advice, as always, is greatly appreciated!
