If you don't mind me asking, what did the TN run you? They were locally selling for 900 for a dealer floor model. I imagine the new ones were 1100 or so. Anything overly annoy you about the stove yet?
$1,024 with legs and no blower.If you don't mind me asking, what did the TN run you? They were locally selling for 900 for a dealer floor model. I imagine the new ones were 1100 or so. Anything overly annoy you about the stove yet?
went to there site looks like a very nice stove.and likely "overnite burns" as well.
I'm getting " overnites" loading good hard well seasoned red oak into a brandie new True North TN19 (1.9 cu ft ) loading full at 8PM and finding coals to get a fire going at 7AM. Certainly not big coals 11 hours later but they'll ignite paper /or chipboard. Stove is no longer "hot" but not stone cold either.
Good choice for a small space. I have one and it works great. Im using it in an apartment im rehabbing, but plan to buy another for a cabin im rebuilding in the woods. Pretty good for quick heat ,something that it does resonably well for an EPA stove.bought the us 2000, well built started breaking it in today easy to start and adjust.
what burn time does it get?Good choice for a small space. I have one and it works great. Im using it in an apartment im rehabbing, but plan to buy another for a cabin im rebuilding in the woods. Pretty good for quick heat ,something that it does resonably well for an EPA stove.
Thats a good question as im not around it long enough to find out. I dont live where i use the stove. I fill and start the stove do my work and go home. Its usually about 18 - 22 hours before im back again. Also i use mostly pine which does not make for a long burn but does make for some quick heat. Eventually i will spend the night in this Apt im rehabbing, so ill get abetter idea if overnight burns are possible.Let me know what your experience is with it for overnight.what burn time does it get?
i will find out next week deer season starts in pa.Thats a good question as im not around it long enough to find out. I dont live where i use the stove. I fill and start the stove do my work and go home. Its usually about 18 - 22 hours before im back again. Also i use mostly pine which does not make for a long burn but does make for some quick heat. Eventually i will spend the night in this Apt im rehabbing, so ill get abetter idea if overnight burns are possible.Let me know what your experience is with it for overnight.
some say they can get 9 -10 hoursMy guess is an overnight burn is asking for a lot from any 2 CU ft Stove.
Depending on how one defines "overnite ", I'm getting 10 and 11 hours out of a new True North TN19 tossing good sized chunks of nice dry red oak and having enough coals in the AM to put a half dozen half inch pine sticks in and a couple small splits of pine, turn the lever to "boost" and in 15 minutes I've got a hot stove top again.My guess is an overnight burn is asking for a lot from any 2 CU ft Stove.
I bought the Country Hearth 2000 from tractor supply on sale at the end of last winter. I replaced a Grandma Fisher in my garage with it. "Was tired of the dirty burn and so much smoke". My garage is about 800 square feet and pretty drafty with insulation overhead only. I like the Country Hearth ok but I miss the brute force heat of the old Granny Fish.hi everyone, new to the forum i wound like to know if i could use the englander 30nc to heat 1000sf , i know its not a big space but i want a over nite burn, thanks for any info.
Not for me. But, as has been said, it depends on what you mean by burn time. If overnight is 8 hours, I can get that with decent heat still coming from the stove (maybe 200F) with alder and fir. I've had enough coals to start a new fire (stove pretty cool) after 11 hours. But so much depends on the wood and technique.My guess is an overnight burn is asking for a lot from any 2 CU ft Stove.
Bingo, threres a very BIG difference in continually heating a space and going into say a garage when its 35-40 deg everything in there is ice cold and trying to get the space comfortable. Even after you manage to get the air temp up it will be hours and hours before everything else warms up .Problem is by that time the occupants are likely long gone.Of course in a garage you are qwite often starting from cold turkey which is harder to achieve with a smaller stove. Just my.02
A 200F stove probable does not contribute much more heat than a coffee maker would. Unless your space is small and very well insulated, i would think you are in for some cold mornings.Not for me. But, as has been said, it depends on what you mean by burn time. If overnight is 8 hours, I can get that with decent heat still coming from the stove (maybe 200F) with alder and fir. I've had enough coals to start a new fire (stove pretty cool) after 11 hours. But so much depends on the wood and technique.
Yea, know what you mean. When you get over 50, you might not want to stay out their as bad as you thought anyway. Ha haI have a 30 in my workshop. Uninsulated with cement walls. It does a good job considering but i dont expect miracles when its 35 degrees in there. Unless ill be in there all day i dont even bother starting the stove.
