Maple1 - There is fire brick lining the bottom between the ash slots and there is fire brick that lines the sides and back.
Now....as far as the ash pan......ash slots...and ash falling outside of the pan problem.
He told me that in his opinion this is a design flaw that they do not want to fix. He said that there are a lot of people spending a lot of time making metal plates and inserts to cover the sides to keep the ash holes over the pan.... his fix was simple.... fire brick... buy some fire brick and lay it down on the sides. Leave the center open for the ash, and for the air to flow through when making a coal bed. This will also hold more heat in the bottom, act like a gauge for making a nice bed of coals and solves the problem because the air that is blocked by the fire brick when making a bed of coals, is minimal. When the spin draft is closed, there is no air being fed in from the bottom anyway. I followed this advise also and will post my own findings. In the worst case I bought a few extra fire bricks that I can take out and keep on hand for the future if / when I need them.
True, BUT, If you have a negative pressure in the basement (which it sounds like you do when the door is shut) then you also have a dangerous situation where smoke/fumes can be pulled from the stove pipe when the blower kicks on. You need to install some sort of dedicated return air duct or vent.I was told that I should run the blower and begin to close the basement door, if the door gets sucked shut, then I am creating a negative air pressure gradient in the basement. With this situation, I should NOT install a barometric damper in the flue pipe because the blower and the damper will be fighting for the same air. I was told that the damper will actually get sucked shut and require more internal "flue pressure" to work properly because of the negative pressure in the basement caused by the blower. Now I could open a window or something to allow more air in the basement to counteract the negative air pressure, but this would defeat the purpose of having a weather-tight sealed house.
Agreed, I actually have a reoccurring task list that includes inspect and if needed clean the flue every 2 months during the burn season. Being a firefighter, having a chimney fire in my own local would not bode well for me.
I have asked many people regarding the barometric damper. Now gain I MUST preface that I have never used one, I know NOTHING about using them, but I have received the same information from different people including my "buddy" .. lol.
I am bringing what I was told here to get more input from a broader spectrum of people, but I must say, what I am about to share seems plausible.
My furnace is in the basement, my home is relatively sealed (not drafty). This is important for the test that I had to do. I am going to try not to bounce around, but please follow me.
The barometric damper was explained to me that it takes air from the surrounding area and automatically adjusts the airflow through the flue by allowing air to enter the damper / flue when needed. Now, we also have a blower on the wood furnace that also takes air from the surrounding area and blows it through the house to disperse the hot air. The air that the wood furnace blower needs is the same air that the barometric damper needs. If you also use the blower on your main furnace to help distribute the air, this uses more of the same air that the damper needs.
NOW...this is where things got interesting.....and this is based on my situation where the house is sealed. I was told that I should run the blower and begin to close the basement door, if the door gets sucked shut, then I am creating a negative air pressure gradient in the basement. With this situation, I should NOT install a barometric damper in the flue pipe because the blower and the damper will be fighting for the same air. I was told that the damper will actually get sucked shut and require more internal "flue pressure" to work properly because of the negative pressure in the basement caused by the blower. Now I could open a window or something to allow more air in the basement to counteract the negative air pressure, but this would defeat the purpose of having a weather-tight sealed house.
....and yes, as I closed the basement door, pushing it with 1 finger from the back, when I got about 3" from closed, the door got sucked shut. I turned off the blower and did the same thing and the door stayed open until I pushed it all the way to closed.
I was told that the barometric damper works well in situations where the house is not well sealed, or in an area like a first floor installation where there is usually more available air so that it can work properly.
Thoughts / commentary.......
Yes the manual says don't do the damper and in some cases it's not helpful but as was mentioned it is a liability thing . The damper not only changes the draft it helps keep heat into the unit .epa units don't need one because they work in a much different fashion with more internal temperature to promote secondary combustion and less incoming air so a strong draft is important when they" close down " . You can watch this happen on a modern EPA stove that's just getting going you close the door prematurely and it snuffs a fire out like you turned off a switch . Esw says to manage your heat output only use the air controls to choke it down ..the fact is though that your only going to reduce air coming into the unit this way and not the heat that's leaving and going out of the the unit . If I had to guess an estimate I'd say adding one gave my old furnace an hour or two of extra burn time . It's worth a try , moniter it and watch for creosote . I would keep the damper fairly close the furnace (2 feet or closer) so as to keep the heat high to prevent potential buildup collecting around the flapI added the probe flue thermo.. what a difference between the 2 gauges.
I was fiddling with the manual flue damper.... trying to dial it in... I was having a bit of trouble keeping the coals, fire temps etc...
I spoke to Englander tech support.... they told me that per the manual "Do not install a flue damper".
So I read the manual.... yep... page 5 of the manual says "DO NOT install a flue pipe damper or any other restrictive device in the exhaust venting system of this unit."
Thoughts?
