Englander 25pdvc baffle plate
Are there suposed to openings on each side of the plate, Mine is not perfectly centered it about maybe an inch off center but the stove puts out loads of heat.
stoveguy2esw said:
pelletizer said:
Would a off center plate possibly be the cause of some people claiming not to get any heat out of these models?
an off centered baffle could result in loss of heat. especially in the pdvc
No problems just talking baffle plates and what not, Some people have had problems not getting any heat and as Mike said an off centered baffle could result in loss of heat. especially in the pdvc
Hey guys sorry to bring up a dead thread, just a quick question about the baffle plate. I skimmed through this and some other threads and didn't see an answer to my question...
My baffle sits forward even when the stove is burning...I know that I read as long as the plate is centered it should be fine...but would I get more heat if the plate was pushed back while the stove is burning?
I think the stove leans forward slightly which is why the plate is forward...I would check the to see if the floor is level but my brother raided my tools and I have yet to see the return of my trusty level.
Again, if I over looked the answer I apologize...just write it on a sticky note and put it on my forehead.
-Chad
EDIT: Just want to make it clear that my stove is putting out great heat and I'm more than happy with it...just wondering if this would increase the heat output at all :-).
I just wish the handle on the baffle plate to my 55-SHP-22 was a little larger and easier to take out.
I don,t think it matters but you could bend the tabs CDodge to make it fit snug,
Strangemainer you could have someone weld a bigger handle on the plate easy.
My baffle plate leans forward slightly as well. I think it's normal.
pelletizer said:
I am completely baffled here :-S
Don't be baffled, we can get a handle on it.
