This is a tough one to describe. I was just reading thru the error codes section on the ESW website, and it stated:
I have noticed when cleaning my stove that the baffle plate has some "play" in it. It slips into the two tabs on the bottom, and then the hook peice (approx 2" long, welded on 1/4"x1/4" steel angle) on the back of the plate engages with the lip of the heat exchanger opening. It then hangs forward on the hook about 1/4" away from the back wall. I can push the plate back, but then it falls forward the 1/4" or so. I thought this was normal, until reading the error code page. (I don't have any error codes, I was just reading for the sake of it) Do I need to correct this, by maybe shimming under the front of the stove so that the baffle plate leans back and rests on the rear wall of the firebox, or is it supposed to lean forward and be retained by the hook?
an improperly positioned baffle plate which would allow exhaust to bypass the top of the heat exchanger, i.e.. If the baffle plate is not positioned flat against the back wall of the firebox at the bottom allowing the fire to get behind it, (this would cause higher exhaust temperatures that could damage the vacuum hose or cause vacuum loss due to lack of air density (the hotter air gets the less dense it becomes, this makes it much harder to sustain vacuum pressure)).
