i figured out a few things about the noise... before i go to bed at night is usualy when i hear it the loudest... i found out that when i turn off the space heater (radiant one that my dog sits in front of) the noise starts up... if i turn it on the noise goes away and so on. by the next morning the noise is gone... the space heater or other loads need to be on for a while and then when you turn them off the noise starts up aagain.
i have been checking the voltage at my outlets thinking that has something to do with it... i found this... stove running with nothing else on the voltage is 118-119 with no noise. when i turn on tv/space heater/lights voltgae drops down to 114-116. this is where i get confused. after a while the voltage creeps back up to the 118 aera and when i turn off all the other loads voltage goes to 120-122 at the outles and stays there. this is when the noise is being made and it will go away after about an hour or so when voltage creeps down to the 119 mark.
im really confused as to why voltage seems to "spike" for such along time. also if i put in a new motor as i have done before the noise is gone for a few weeks completely. so i dont know if the higher voltage is just bring out the bad motor/stove noise or it is causing it entirely.
im going to check the voltage on both the main leads of the house and if one or both are too high call m y elec company and see if they can adjust it lower at the pole as i have heard they can. i have heard 108-120 is normal voltage to be seeing tho. im currious to see if your voltage varrys as mine does.
