Hand-me-down 2001 Englander 25-PVCD/55, given to us with a ton of TSC white bag pellets.
I did the burner plate mod, leaf blower vac, and changed it to 4-4-1 mode D.
TSC pellets burned "OK". Approx. 18-20 hours per bag. The ash was fluffy, light gray. Burn pot fills with ash in approx. 6-8 hours, reducing the burn area to a couple of inches. Side ash chambers are half full after 3 bags. Glass is sooted in 3-6 hours, depending on burn rate (manual between 3 and 6). Turned the stove to 8 one day to clear the hopper and noticed that the glass started to clear.
Installed thermostat. Pellet usage increased to approx. 14-16 hours per bag, regardless of heat setting at 5, 6, 7, or 8.
I've tried multiple brands of premium pellets, hard and soft.
Stove Chow, Fireside Ultra, Maine Pellet, LaCrete, N.E. Pellet, Okanagan, Super Spruce.
Almost every brand burns hotter than TSC in this stove, but most of them also burn dirtier (black, heavy ash). The ton of TSC lasted almost 2 months because I spent every weekend testing bags of different brands. Now, I'm buying TSC per bag until I determine what I pellet to have delivered... and have concluded that the current TSC pellets also burn dirtier than my original palate.
The BIGGEST ISSUE is that I cannot run the stove on the thermostat now. The stove will not sustain "idle" mode 1. During idle, the pellets drop into the burn pot and just smother the pile of embers. It either extinguishes completely, or it smolders for a few minutes then lights dirty. I've increased and decreased the LFF and LAF settings. It still goes out. If the flame survives until thermostat on, the first load of "heat on" pellets also smothers the embers. I'm now running with the thermostat bypassed in constant heat setting 3.
I feel like the stove drops too many pellets at too long of an interval. Meaning the flame dies, the embers almost extinguish, then about 1/2 a handful of pellets drop all at once and create a 10-12" flame, repeat. That's at 4-4-1. Only Super Spruce could sustain 3-4-1, still not consistently though. I would expect idle mode to drop a few pellets at a consistent rate, maintaining a steady small flame... ??? BTW, the lower auger spins 1.5 RPM.
I desperately need help to get this stove running proper.
![Englander 25-PVCD: Need help please Englander 25-PVCD: Need help please](https://www.hearth.com/talk/data/attachments/257/257507-e9753339ae9662646268d1f5750fcaf3.jpg)
![Englander 25-PVCD: Need help please Englander 25-PVCD: Need help please](https://www.hearth.com/talk/data/attachments/257/257508-d2cd1ee51751f563d6919dfc73d6e74d.jpg)
