Hi All!
I am looking for some advice on which size stove to go with. I have been looking at the Englander 13-NCH which is rated for 1800 sqft or the 30-NCH which is rated for 2400 sqft.
13-NCH
http://www.homedepot.com/p/Englander-1-800-sq-ft-Wood-Burning-Stove-13-NCH/100157775
30-NCH
http://www.homedepot.com/p/Englander-2-400-sq-ft-Wood-Burning-Stove-30-NCH/100291302
The stove will be in a room with approximately 700 sq ft and there is another room with an open doorway that the heat will travel into but not be used to really heat. That room is approximately 400 sqft. I may convert my garage into livable space which will add another possible 400-500 sqft but not anytime soon.
I am wondering how accurate the 1800 sqft specification is for the 13-NCH. If its true to 1800 sqft then I think I would be fine with that stove but not sure if it is thus I am turning to the knowledgable community here for some advice.
My current stove is a very old timberline stove that came with the house when I bought it 10 years ago. Same as the one from this old thread.
https://www.hearth.com/talk/threads/timberline-wood-stove.101525/
Seems like it was from the 80's, its very big and old. I believe its pre-epa as people have called it on this forum. We have to run fires very low and slow to keep the house(really the room I stated above) from being 90+. If we were to run it full out at 600+ degrees, it would easily hit 90 in a short period and burn through wood like crazy. It seems as though it was made to heat the whole house, not just the immediate room it was in.
I would like to upgrade so that I can use less wood and have longer burns. Right now the stove pretty much has to be baby sat all the time. I would like to load it, get it going and hopefully leave it for 7+ hours. It seems like that is the norm for most stoves today that are either cat or not "pre-epa". The price difference between the two stoves is not a factor. I also have decided that I do not want a cat stove from what I have read on here.
Which size do you suggest? Any help is greatly appreciated and thanks in advance.
13-NCH
30-NCH
Thanks for the info.
