The gear motors for the augers come in different speeds. I have seen 1rpm to 4rpm and speeds in between. On mine, I let it rotate until the set screw was facing me, then timed how many revolutions it made in a minute. I think mine was 1.5. I can't tell you if ESW uses different speed motors in their stoves.Im using Premium Wood Pellet Fuel from Tractor Supply Company, but its the same pellets that I was using before the breakdown.
I oredered the motor from ESW.
Cladmaster the stove has not improved I thought that it was improving but once it caught fire it just burned through everything way to fast. How do I increase the feed rate? As of right now I am letting go into shutdown mode and then I will try a master reset again and change it to a c setting this time. I could also check the motor RPMs What am I looking for with the motor RPMs How long it takes for it to revolve?
