I've got a tricky situation. I was looking to replace my ventless gas fireplace with wood for this winter. I ended up ordering an Osburn matrix insert, at the time not not distinguishing zero clearance woodburning fireplaces and fireplace inserts.
When I removed the old ventless gas fireplace, it revealed a wood frame underneath which is in conflict with the requirements of matrix insert to have a masonry chimney.
Returning this unit for a refund is not an option at this point. So I want to see what my options are as far as engineering something within this space that would still be safe enough to operate.
As far as the chimney pipe goes, I am going to be using a triple wall duravent all the way through the roof to get that 2" clearance.
As far as preventing the wood around the insert from getting baked and catching on fire:
- Lining the entire inside of the builtin cavity with cement board along with rockwool insulation, making sure no wood is exposed inside
- Placing the insert on 2 sets of bricks covering it's entire footprint underneath
- Placing more rockwool batting to cover the subfloor of the builtin
- inserting a vent for airflow at the top of the cavity coming into the room to allow hot air to escape out of the built in
- using cement board to fill in the rest of the hole on the face of the builtin and finishing with the same rock
- any wood facing the insert would get insulation
Thoughts on this?
It's okay to say that this is a bad idea, but looking for a genuine discussion of solutions as well. I am not worried about inspections where i am. Thank you
Thoughts on this?
