That looks like the normal shakes to me, mine does the same and a friend's with the Robin engine does as well.
I actually have a single cylinder Kubota diesel mounted low on mine and it seems to shake the table about the same as yours.
I added two layers of 3/8" rubber conveyor belting on the front leg, as wide as the front foot. Bolted on with the existing 4 bolt holes such that it forms a circle that flattens out mostly with weight on it. The rubber is then the shape of a folded or installed staple with the bolt heads inside the "circle" of rubber. If that's not clear I can find or take a picture?
This helped some with the table shaking and all around seems like a good idea even if your machine didn't shake.
