Encore draft or airleak problems
Dgcarlso3
3
WI
Hello all,
First post introduction...I bought my first house in 1993 which came with a Federal Airtight stove. Got rather addicted to wood heat, so I refinished by basement and bought a Jotul Firelight (the catalytic model), which i ran 24/7 in the winter here in WI. Both of those stoves were very controllable and I was able to snuff the fire down to nothing. I did need a flue damper for the Jotul. I got used to being able to turn the stove down until the logs were just smoldering.
Fast forward to now, I just had a new Encore 2040 cat-c installed. It seems to have either an air leak or too strong of a draft, or I have the wrong expectations of much more modern stove standards. Below is a link to my fire this morning, restarted from coals. This was taken with the air control on low and the cat engaged. It seems far too much flames, although it does not run away.
Does this look like this stove should run at low? This is the first question I would like to answer. If not, then I was planning to test per this message: https://www.hearth.com/talk/threads/encore-2040-cat-c-burns-too-fast.205794/page-2#post-2753548 unless anyone has a better starting point.
Attached is a Pic of my installation. It is about 18 feet from the floor to the ceiling at the chimney adapter. There is about 8-10 feet of class A chimney on my roof, and the connector pipe inside the house is double wall. The total flue length then is about 24-26 feet.
I am burning seasoned hardwood mix right now, purchased from a local reputable dealer. I don't have a moisture meter, but they season it about 2 years and random logs whacked together passed the ring tone test. Super hi-tech test there, I realize :)
Thanks!!!
  • [Hearth.com] Encore draft or airleak problems
Looks pretty active. I reloaded mine this morning and engaged the cat, cut it back at 900. It creeped into the 1000's and then went to 1400. I shut the air and it's now at 1100 and the box is very dark with no flames dancing just a glow at the bottom of the load. I have had it stay active for a while when I've shut the air but it eventually calms down.
What does the cat thermometer say?
I am using the cat temp monitor that came with the stove, and even when I have the air intake on the lowest setting, the indicator is at the high end of the range, often over it. The stt also rises to 700 on a magnetic temp indicator. I don't trust the "absolute temp reading" on either of these, but both indicate the stove is running hot at the lowest setting, so I am questioning if I have proper control of the burn.
The video I posted shows both full open and full closed air settings. Is this how I should expect this stove to run at the lowest setting? Also, does the picture of my installation look like my flue length might be too long for this stove?
I did an experiment yesterday. I shoveled ashes up over the holes in the ceramic, I think these are for secondary? The stove ran MUCH differently and I was able to control it all the way from a high burn down to smoldering. Nit sure what I should take away from this...
