Some more time so I cleaned the right side panel. Same routine as the fireback - two handed approach with a dremel/grinding bit and shop vac to clean the gasket channel. Seems tedious at first but I got it done in under an hour. Then a quick wire brushing over the rest of the panel.
Whoever did this one last figured if some glue is good a lot more is better. There was tons of cement squeezed out around the gaksets...
![[Hearth.com] Encore 2550 rebuild... start to finish [Hearth.com] Encore 2550 rebuild... start to finish](https://www.hearth.com/talk/data/attachments/108/108779-cf97de6ad9133b7638e089a56331710e.jpg?hash=JOvEAublIQ)
My wife has started making pies. That must be a sign fall is coming. Time to pick up the pace!
![[Hearth.com] Encore 2550 rebuild... start to finish [Hearth.com] Encore 2550 rebuild... start to finish](https://www.hearth.com/talk/data/attachments/108/108814-b932fd0617752a2a25504735d75f8c7d.jpg?hash=v19_iG3ppD)
![[Hearth.com] Encore 2550 rebuild... start to finish [Hearth.com] Encore 2550 rebuild... start to finish](https://www.hearth.com/talk/data/attachments/109/109017-e2fd726f119de1176da6b5d89b94ea5e.jpg?hash=BTUN0Nw6Ft)
![[Hearth.com] Encore 2550 rebuild... start to finish [Hearth.com] Encore 2550 rebuild... start to finish](https://www.hearth.com/talk/data/attachments/109/109018-af49bd3383d44b997595008ab3a6bf63.jpg?hash=I-2DtdyfVi)
![[Hearth.com] Encore 2550 rebuild... start to finish [Hearth.com] Encore 2550 rebuild... start to finish](https://www.hearth.com/talk/data/attachments/109/109019-3f469f24138cfc11e5a26080099e64f7.jpg?hash=04i6RlFgsM)
Looks like you are going all the way to do it right.
