Rhonemas said:wahoowad said:precaud,
How does this apply to the "glass" on my stove? I am thinking heat is radiating thru it, and not necessarily off of it. I defiantely feel a lot more radiant heat a foot away from the "glass" than a foot away from the side.
Radiated energy's power is based on the temperature, size, and shape. For example, if your stove is biggest in the front and smaller on the sides, the front is going to have more power than the sides, if your sides are bigger, they'll have more power (if it's a unit without firebrick). As an experiment to show how radiant energy comes out from flat surfaces, approach your stove diagonally. Since there's almost no flat surfaces facing you, you should feel very little radiant energy and can get really close (and why stoves can be placed diagonally close to walls and have tighter clearances than square to a wall). Then, stand directly in the middle of the biggest flat side, same distance and see how long you can take it. Because radiant energy comes out most from flat surfaces, round/barrel stoves are better designs because it spreads the heat out more evenly around the room instead of creating hot spots. With flat surfaces though, you can strategically place people. For example, I know the seat directly in front of my glass is the hottest seat in my house and the wife who likes heat... that's her spot. I don't like it, so I sit diagonally to the front.
So, my guess is the glass in front is bigger than the sides of your stove, and your stove sides probably have firebrick insulating and protecting them from reaching the same temps as the glass in front, so your glass is emitting more energy. Also, radiant energy is a form of light, and follows the inverse square law which means every time you double your distance from the source, the intensity is reduced by 1/4th. It's still the same amount of energy in the end but it's being spread over 4x more area everytime you double your distance so you notice a pretty quick drop off, or gain depending on which direction from the source you're going in.
Maybe implied here? Radian't heat of the fire itself does go through the glass...just like the light does.
