Dan,
Crap!
I just lost a 6,000 character post because I bumped into the "character limit Gremlin."  You know, where you type ONE CHARACTER TOO MANY AND THE WHOLE POST DISAPPEARS!  Arrgghhh
!! (It may happen when hitting "Backspace" while at the char. limit--not sure).
In short, I refused to buy any steel, NC stove that doesn't offer thermostatic control of the PRIMARY (and possibly secondary) air supply, other than the Englander 30-NC.  I've studed the steel-plate, non-cat stove market extensively, for too many years,
and the Englander 30-NC is meeting or exceeding all performance measures of the $2,200-3,000+ stove market, at 1/3 to 1/6 the price (if you get one at 50% off at Lowes, as I just did), against even such formiddable models as the Quad 5700.
IOW, if I can't have thermo-control of the PRIMARY intake air, for $3,000.+, then why would I spend such money, when the Englander 30-NC meets or exceeds the perfomance of such $3,000/+ stoves, at 1/3 the price? (Or 1/6, if purchased at a 50% discount.).
Thermostatic control is the single biggest feature I seek, after materials choice.
In 2007, I contacted every major steel stove mfr. and asked if they were going to offer thermo control.  Quad mumbled "maybe, since we have our ACC system on the market," but the only serious response I got was from Mike at Englander, saying he would forward my suggestion to "the slide-rule types" (my term, not his).  I felt the other mfrs. were just blowing me off--though I felt Quad
might have been serious, but I doubt it.  I do believe Mike has passed my concerns up the channel, and we shall see if they respond as I hope they will.  If they do, my second stove will be an Englander as well!
I know PE offers thermo control of the SECONDARY air intake, but feel that is too little to accomplish what I, and now YOU, would like to see, i.e.,
full thermo-control, where one could select a rate of burn, load the stove, and forget it, knowing it's metering the air necessary for complete, efficient combustion at the output level selected by the operator.
I know Blaze King offers thermo control, but don't want a cat stove.  I also know some cast iron stoves offer thermo control (Quad's Island Royale, possibly?) but again, I don't want any cat, or cast, stoves.  (No offense to such owners--it's just that I'm l-a-z-y, and don't like replacing cats or furnace cement.  Welded, plate steel stoves make me feel more confident about their integrity than stoves bolted together with furnace cement, but that is my personal preference.  I only mention it here because I want Dan to offer his electronic system to OEM's of
plate steel, welded stoves, so I can buy one! LOL)
But to recap:  I put off spending $3,000+ on a stove that lacks even the bimetallic intake air control that even some of the smoke dragons of the '70's had.
If the Englander hadn't been available at 1/3 the price of the Quad 5700, I would have bought NO stove.  So when the Englander 30-NC became availbable for 50% off, or ONE-SIXTH the price of the Quad 5700, but with comparable performance and superior emissions, I bit.
But I'm determined to wait to spend $3,000. for a "pretty" stove until thermostatic control of the primary intake air is available.  And, when that is offered, I will buy the new stove and move the 30-NC to my cottage.
Re: the concerns I share with others about a failure leading to a runaway stove, please address this:
I feel the electronic servo should pull against an extension spring that is contantly trying to close the draft, similar to how, on a garden tractor engine, the operator opens the throttle against a governor that is contantly trying to close the throttle.  I see this as a common-sense approach to avoiding a failure that results in a runaway.
I would be into the electronic control's additional features of "logging," remote control and particularly, OVER-FIRE ALERTS and low-fuel alerts, IF I FELT THE FAIL SAFE MODE WOULD RESULT IN A CLOSED DRAFT, and if the stove could be run MANUALLY in case of extended blackouts.
Sorry I can't write more,
and sorry for the mistakes and poor writing--as I say, I was one character away from a well-groomed post, answering all of your Q's, when *POOF!* it was gone.  I forgot to write it in Word
first and post it here, and having been burned like this too many times in the past (sorry, Craig, but it happens to me, too often--I know, I'm a "wordy ****  :lol: ) I'm just too frustrated to rewrite the whole thing.
I seriously hope you pull this off, Dan.
If for no other reason that it should spur the OEM's to get off their asses and offer the same thing, so we can have the same convenience enjoyed by pellet stove owners, for cryin' out loud!  It's about FORTY YEARS OVERDUE, since it was offered in the '70's, right?
I would also be interested in a retrofit kit for the Englander NC-30, Quad 5700, etc..., IF you could offer strong assurances that Homeowners carriers and code enforcements' concerns could be met, especially without risking denial of coverage should the woodstove (for any reason, not necessarily involving your system) be cited as the cause to a house fire (knock on wood three times.)  And I have to tell you that, as an attorney, I think that will be an uphill battle, in terms of a retrofit that won't make the carriers underwriters
jump right out of their trees in an effort to say "NO" to covering such a mod. Perhaps if a licensed professional HVAC guy/gal did the modification, that would help, but I don't know.  I didn't practice in the area of products liability, however, so value my .02 accordingly, on this last point.
I truly wish you the best of luck in pulling this off!
And yes, to sharp the sharp-witted like BB, I realize this post is as long as the one I lost--it's just more rambling and disorganized.  ;-P
Thanks again.
