paulnlee
I understand that, and totally follow what you’re saying, but we’re getting hung up on the original point. Relays are electromechanical devices, not “electronics”. Modern electronics, with very few exceptions, run on low voltage DC. Most frequently 3.3VDC. The OPs reversed outlet will have no bearing on them.
Most modern appliances are double-insulated, they likewise will not care about the reversed wiring. Some old appliances bonded the chassis to neutral, but folks figured out that was a problem 50 years ago, when mom got shocked by touching the electric range and refrigerator at the same time. Today, all major appliances have a separate (un-bonded) earth ground connection to the chassis (3 prong outlet), and it is illegal for manufacturers to bond neutral to the chassis.
I’m not sure this argument is still in the best interest of answering the OP’s question, nor am I saying you don’t know your appliances, I think we’re just getting hung up on symantics.
You're right about the OP. I consider anything with a circuit board "electronics" Had to change one today,$350.00 circuit board not supplying 120 to the xfmr to supply low voltage DC to the lights.
