I'm installing a sub panel in my attached garage. 200 amp service at the main box. I am running 2/2/2/4 Al SER about 25' through a crawlspace to the wall between the house and garage, where I will mount the subpanel. Inspector confirmed this is not considered a fire wall in my single family residence. He also said the 2/2/2/4 is good for 90 amps, but I am just going to do a 60 amp breaker in the main for now and can always up it later in the rare chance I need more.
With the wall cavity open it's easy to run cable up through the wall and into the new panel. For now I'm just going to add a 240V/50A welder outlet, a 240V/30A compressor circuit and a few 125V/20A outlets.
I have access to the unfinished attic, above, and to the crawspace below/behind (garage on slab, crawlspace under adjoining house). In the future I could fish wires down from the attic or up through the crawlspace, not sure how I would attach cable clamps to the box once it's in the wall. Is there something I should be doing now to make my life easier when I want to add more circuits later? Should I run a few stubs up/down to junction boxes? Or maybe a few pieces of conduit? But I think no NM/B in conduit. Cut out more sheetrock and install an access panel? I like to keep things clean as possible...
![Electrician types... any input on garage sub panel install? Electrician types... any input on garage sub panel install?](https://www.hearth.com/talk/data/attachments/159/159855-a312e7016706e27ca3abe6f227245083.jpg)
