Does the garage has a dedicated GFI breaker? Turn the garage outlets circuit breaker off, then on and see if that helps. If it trips immediately, a short was introduced with the outlet change.
Hey, could some dope have wired the outlets through a switch?
Sorry, I should have been more clear - I have two panels (one smaller one for generator) and every circuit is labeled but none of them are labeled "garage outlets". The closest I can come is one that is labeled "garage lights" and that is definitely not the circuit. So I was guessing and trying other circuits for rooms around the garage trying to find the garage outlets. Never found it before I swapped out the outlet and then this fun started.
I'm still at a bit of a loss. I guess step one as has been suggested is to find the circuit and begin tracing it to the garage. Perhaps I need not go any further than the panel if that breaker turns out to be bad. I do have a non-contact voltage sensor that I have been using...
Good guess. Could be the breaker. I've had them go bad after I tripped them. The only real way to tell is to start figuring out how far the current goes.Sorry, I should have been more clear - I have two panels (one smaller one for generator) and every circuit is labeled but none of them are labeled "garage outlets". The closest I can come is one that is labeled "garage lights" and that is definitely not the circuit. So I was guessing and trying other circuits for rooms around the garage trying to find the garage outlets. Never found it before I swapped out the outlet and then this fun started.
Well, since you plead guilty to the crime of not finding the missing GFIC outlet...
I sentence you to going to your circuit breaker panel, and turning off each breaker one at a time and finding out what is off, then LABELING the breaker box circuits with a Sharpie pen. I could also sentence you to adding GFIC stickers to the outlets that are downwind from your GFIC outlets and thus protected but the goons that wired your house circuits, but maybe that would be going too far.
