I am looking for a small splitter. 5 ton splitter. After 1 season I am realizing that cutting wood is tiresome. Anybody have a good brand 5 ton splitter they can recommend? Maybe northern tool?
There's a couple ways to work around that. My splitter has a button plus a lever that has to be depressed to activate the ram. For shorter pieces, if you push the lever down when it retracts part way, the ram stops at that point. Then you reduce the ram travel & time by the distance that you are not using. Another way is to put a 8" piece of squared wood at the end of the ram. Of course, both ways add to the danger of an already dangerous job. Even an electric splitter can cause splits to fly out at astonishing speeds.Keep in mind they have a really slow cycle time - usually.
Just purchased a Blue Max 7 ton splitter. Should be delivered within the week.
I've read some positive reviews on the Pow R Kraft. They seem to be built well and last longer than cheaper ones. You may wish to upgrade to a 7-ton model. 5 tons sounds like a lot but it isn't when you've got knotty yard tree oak to work with.
I have the 5 ton Harbor Freight, most of their stuff is hit or miss, but this thing has been great. Depends on what your doing I've busted up several a 24"+ rounds no problem, it was pine thoughbut for resplitting yellow birch, Ash, Oak chucks its great! The best part is 1 hand operation (don't need to hold a safety and the lever and it doesn't have to cycle back to the start position before you can start again) The wheels kinda suck on it and its heavy but the hand truck idea is a good one.
The 20 or 25% off coupons are easy to come by, I think I paid $225 around last Christmas time for it.
http://www.harborfreight.com/5-ton-log-splitter-61373.html
