Electric splitter at distance?
PLAYS WITH FIRE said:
I am an electrical engineer but by no means an expert on all things electrical. I am not an expert on rules of thumb or what is exceptable voltage drops for certain equipment. I look at mafg data or use the web etc.. I picked 3% and used a my fundamental circuits book by Boylstad. This is the calculation you use and maybe not the acceptable % voltage drop per foot of wire using as an extension cord. However if you use the online calculators, it will yeild the same answer.
I would have guessed that you were an electrical engineer as I went through this before with some engineers who did the calculations for voltage drop on a wind turbine circuit. I have been wiring for a long time now and have used the 10% for most loads, makes sense you would want the 3% for switch gear and panels so you start up with a strong circuit. I can assure you that load will run on a #10 cord and the 12 might even be fine, I have that much #12 cord here and if I had the time I could do an acid test but I still think he should just move the wood closer to the building.
Wow... and this all started with "What kind of extension cord do I need?"....
That is why this place is the best place for ALL information!:-) Very knowledgable and very detailed folks here!
