Inspection and results of the nozzle plate I made last fall before the start of the 2013 - 2014 heating season.
Very pleased.
Video link:
Enjoy!
Very pleased.
Video link:
Enjoy!
Very nicely done JT on the guard and video! I think your idea of the row of holes is better than the undersized slot I did this season. My 3/16" plate warped badly in the middle which I attributed mainly to not enough thickness. But now that I think about it, it warped the worst in the middle where the slot was unattached side to side. I'll bet that metal between the holes helps prevent the warping I experienced. But I will also go thicker next season. Those holes have to be better at keeping larger clinkers falling thru also.
I also like your idea of the pins to locate the guard on the nozzle. I sized my plate to be positioned by the end and side ceramics which was often not precisely on the nozzle because of gunk. Positioning on the nozzle opening really makes the size of the guard far less important.
Good job.... gonna be a bunch of guys besides me copying the "JT Guard".
I hope the nozzle in your boiler will be easier than the one on my Eko. It was an absolute nightmare!Im going to try something like that with the holes, this fall when I change my nozzle.
Hi JT. Very nice job on the nozzle plate. The nozzle on my EKO40 is very warn and I will likely replace it before the next heating season. It lasted 7 heating seasons, but is now starting to drop too many coals and I think causing increased bridging.
Just curious how your nozzle plate has held up. Is there any warping occurring? I was thinking of using thicker stainless, but if your 1/4" plate is not warping then I will not bother. I have a full machine shop so drilling will not be an issue.
Howdy. I came up with another nozzle plate design, which I have been using this entire heating season. It overcomes some of the issues that I had with the thick plate (this one is 1/16-inch thick). If I find a photo, I will post it for you. Second year on this nozzle - absolutely no wear. Just a suggestion, on another post the guy cut fit a piece of rigid foam inside the nozzle then simply repaired the nozzle using castable refractory. Seems a lot easier (and cheaper) than replacing the entire thing.
I put pressure on the bottoms of my nozzles with a hydraulic jack and then tapped and jacked until they popped out. Tapping inside the slot with a hammer seemed to work pretty well, and it avoids the chance of damaging the refractory.
I made up quick drawing. enjoy!Hi JT. Very nice job on the nozzle plate. The nozzle on my EKO40 is very worn and I will likely replace it before the next heating season. It lasted 7 heating seasons, but is now starting to drop too many coals and I think causing increased bridging.
The vanes do a couple things. First, they limit the size of charcoal/wood embers that can fall into the lower chamber. I never get anything larger than a pea...usually just ash. The second thing they do is to help maintain the shape of the device. Without them it would warp and heave much more than it does, which is not much.Much more than a quick drawing... ready to sent out for manufacture (or patent)! Thanks much. Curious on the purpose of the vanes. Are they primarily to help support the bottom of the legs to reduce warping?
The stainless plate in place.
This is 3/8 thick stainless, 4 inch wide barstock, 20 inches long. The slot in the middle is 5/8 by 6 inches, cut by the fab shop. 4 1/4 inch stainless bolts are threaded into the plate to center it in the slot. Total cost for the fab work was less than $90, and it seems to work very well so far.
