Hydronics said:
Gooserider said:
Hydronics said:
It should work either way but putting the BD on the inlet of the inducer would waste some of the energy.
IMHO it would waste energy ONLY if the inducer is pulling more air into it than the boiler can supply without giving more resistance than the setting on the BD. If the boiler resistance is less then the air will come in via the boiler and the BD will stay closed. If the boiler resistance is greater, then some of the air will come through the boiler, and the BD will open just enough to supply the difference - but is this really a problem??? If it is, wouldn't it be a simple matter to either increase the setting on the BD, or turn down the speed on the inducer?
Note that at least in theory, it wouldn't be at all difficult to create an electromagnet or motorized way to force the BD to close when the inducer was operating. That there doesn't seem to be such a product commonly on the market would suggest to me that it probably isn't seen as being needed...
Gooserider
It's not a problem provided there is adequate draft after the BD opens to prevent smoke out the door if that's your goal. The BD setting should be based on the desired draft under normal operation. If you set it up with the BD on the inducer's discharge none of this is an issue & you can turn down the speed to where it's only enough to prevent smoke out the door. The inducer won't pull air needlessly through the BD. This will minimize energy usage, granted, it's minimal.
If you intend to operate the boiler with the inducer running you wouldn't want to do this as it makes the BD ineffective unless chimney draft is greater than the inducer's. If that's the case, the inducer wouldn't be needed in the first place.
The more I think abou this, the more I feel that having the BD on the discharge side of the inducer is a BAD idea... As you said, if the chimney is drafting more than the inducer is pushing, then the inducer wouldn't really be needed. OTOH, if the chimney is drafting LESS than the inducer, then the inducer is going to be positively pressurizing the chimney on it's discharge side, meaning that smoke will potentially come out any openings, and BD's do NOT seal air-tight when closed...
OTOH if the BD is on the intake side of the inducer, along with the boiler, then any positive pressure on the inducer discharge side should be no problem, as long as the rest of the chimney is properly sealed. The inducer will help to ensure that the chimney on the intake side is definitely under negative pressure, thus reducing the odds of any smoke coming out the BD.
Gooserider
