EKO flue size
easternbob
228
Central NY
The new EKO manual states that you need a 8" diameter flue. I have a EKO 25 and that seems really big. I'm thinking it would be easier to maintain a good draft and the necessary stack temps with a 6" pipe? I purchased a draft inducer along with my boiler and plan on installing that in addition. I realize I need to start out with a 8" tee off the back of the boiler but was thinking of transitioning to 6" above that.
What size flues are other people using and how is it working?
Thanks,
Bob
You'll find that several people on this site are running 6" pipe on the 25's and 40's with good results. You may also notice that a Class A 6" T will fit right over your 8" outlet....quite convienent....except that running Class A chimney pipe indoors is kinda pricey and not necessary for code.
I haven't fired mine up yet but I am using a 7" flue/chimney because the pipe was already installed in my garage. Dave at Cazy Heat recommends using a 6" chimney, because you can slip the collar of a 6" insulated chimney section right over the 8" flue collar on the back of the EKO - he showed me this in the store and I was impressed with the simplicity of the setup. Unfortunately for me I could not use this solution.
I think that 6" is lots, especially with a draft inducer. I live in just about the worst possible place for downdraft and haven't had a problem with the 6" chimney on my PE stove using a venturi cap on the top. In normal operation the only part of that chimney that gets any crosote buildup is the cap itself.
