Wow !
I finally have my EKO40 installed and am using it with 2 x 500 gallon of water storage.
I have been burning it for about a week now and have experienced a few problems and was hoping someone can help me out:
1.) Excessive amounts of creosote build up are occuring in the upper burn chamber (I am burning hard maple that has an approx. moisture content of 20 %). This is causing the flap and door to stick.
2.) I am having to move the logs around in the upper chamber quite frequently (every few hours) when burning in the gasification mode or else my gasification burn goes to zero. However, when its burning properly it does burn very nice and hot with no smoke out the chimney.
I was reading through the EKO manual and noticed that my fan opening was supposed to be at 100% open for the EKO 40 but is currently only 50 % open (as received from Cozy Heat). This leads me to believe that maybe the secondary and primary air settings are not correct either. Before I take off the cover and check these settings I was wandering if anyone else has been through the learning curves and have achieve the best settings.
Thanks everyone for your help !!
Brian
Brian
...Keep warm...Cave2k
