Smokin, after reading this I decided to check the book again, it says 13,500 is the maximum permissible speed with bar & chain. Just above that on page 51 it says ISO 7293 : 9500 RPMHeck my 880 was 11,500.
Found it, is that the noise when it flutters?I'm never good at explaining the sound, but it is basically the "burble" sound at WOT.... there is a wav file floating around on madsens saw site I believe and a nice example on the arboristsite if you do a search. If you have a good dealer, ask him to fire up a saw and let you hear it.
I stopped by the local stihl dealer this morning so I could confirm the rpm's, before I left I noticed this older chainsaw (090) must have weighed 30 lbs. He explained that a customer bought a new 880 so he took it in on trade, did a carb job on it an he will be testing it out this weekend. I did ask him how much for the saw, out of his mouth came it will go in my personal stock.Yes..... start at 12,500 with your saw and you should definitely hear it.....then lean the H (clockwise) some and hear the sound start to lessen. Your rpm's will increase. Have your tach going too and just don't go over 13,500 for very long (btw, the saw will not self destruct if you see 13,700-13,800) the max rpm of 13,500 is likely +/- 500.
Bet you'll settle around 13000-13200 where you can here it burble on top, but when you put the saw in wood the burble cleans up quickly (goes from "4 stroking" to "2 stroking") which is what you want.
Zap, that is an excellent reference page for ANYONE trying to tune a saw. That "flutter" sound is exactly what you want, when you plunge into a round with the chain it will smooth out (under load). That guarantees your saw is getting lubrication/proper fuel mix under full throttle and full load. Great link, everyone out there that wants to know how to tune their saw by ear NEEDS to listen to these WAV files on that link. Thanks for sharing, bud......
Oh how I long for an 090 or Contra. 13hp of raw tree destroying mahem! Someday, boys...someday.....View attachment 64304 View attachment 64302
zap
The 660 was at 14000 rpmsYes..... start at 12,500 with your saw and you should definitely hear it.....then lean the H (clockwise) some and hear the sound start to lessen. Your rpm's will increase. Have your tach going too and just don't go over 13,500 for very long (btw, the saw will not self destruct if you see 13,700-13,800) the max rpm of 13,500 is likely +/- 500.
The 660 was at 14000 rpmsI have it about 13200, the low idle is a tad over 2500. I'm checking all three saws again tomorrow. The manual for the 310 & 390 gave the idle speed at 2800 but I could not find the high rpm settings. Both the 310 & 390 read 13000 on the Tach.
zapView attachment 64308View attachment 64309View attachment 64310
Thanks Smokin, I had just emailed Stihl on the settings for the 310 & 390. I'm glad I checked the 660 before we started milling.
zap
Just received the email from stihl on the high rpm settings for the 310 & 390, 13000 on both.should be 12.5 to 13.5 range. If you want it perfect its with your ear. Every saw will be just a tad different. Even the exhaust guts loosing up will chang it from a stock number.
Oh how I long for an 090 or Contra. 13hp of raw tree destroying mahem! Someday, boys...someday.....![]()
Oh you know it.The most powerful stock 1 man saw ever built. Even 1 of those legendary 1950's beasts like McCulloch 1225A or Disston 101 @15 or so HP were 2 man saws that weighed at least twice as much.![]()
