Hey Boiler room!
I am new to the storage tank end of boilers and have only had a boiler for two seasons and it sure beats propane dhw and fuel oil heat. Edpm sounds like the liner to have as I am restricted to an open storage tank that will be dyi. Estimated 5'h/5.5-6'dia. Due to height restrictions in my basement (old MI home) the tank will sit 2' deep on a poured slab so only 3' will extend up into the basement area. Any how, where does a person find this edpm liner that is being referred to?
Another question I have is about stratification. Since my tank is non pressurized "Is stratification important to me?" My single coil plan is heat the side arm dhw then my water/ air heatx. then pass on through to supply my storage tank unless I should heat my storage tank first(?). I will have ball valves and a by-pass to manually control water going to my storage tank if the tanks is first in the system to control initial start up but eventually it will be a straight shot into the tank. I have a circ-pump on manual that runs 24-7 and I figured if the tank is last in the system that it would charge whenever there is no call for heat if the tank is last in the circuit before going back to the boiler.
The coil I am building from hard copper so I can design coil flow to control how the water is moved through the tank. Theoretically water will flow in a "vertical up/horizontal out/vertical down/horizontal in" repeated circuit that resembles a large fan blade from the top. I know it's labor intensive but soft copper does not lend itself to "buy this part today and that part next week assembly." Since by design the "coil" will address both upper and lower limits of the tank I am inclined to believe there will be no stratification on any serious degree nor would it be desired. Are there any suggestions out there? Thanks...
