Econoburn Ewb 300 blower shut down using a PID CONTROLLER
mark cline
797
Cattaraugus, NY
I want to wire in a pid controller for the blower to shut down before a different PID controller shuts down all power to boiler . Very Leary to splice into wiring that might fry my control board. This seems simple, but my PID has 120v when it’s on ( out light on) . Are there settings in the controller that would just cut power like a light a switch , like the same as disconnecting the aquastat. How has other Econoburn users done this ?
Are you planning to control it using the flue, or water temperature?
Flue temperature, I have a of controller for the total boiler shut down, i want the fan to shut off at a higher temperature
Watching...
Been looking for a simple way to do this.
I bought some adjustable snap disc's from the bay,i have one hooked up to a light and it seems to be at an ok position for shutting the light off when the firebox is empty and the coal bed is used up.
I was,am going to get an electrician to hook the snap disk up through a relay to shut off the fan,maybe the complete boiler.
The PID controller that I put in was simple and easy to put in and program . On YouTube there is a guy his name is George from Hops and barley or barley and hops . I used the Inkbird 106 vh ssr controller , he goes through and explains how it works and how to make every connection. Then there is another video on how to program the PID. It works like a charm but I want to go one step further to shut down the blower then at a lower temp the total shut down will turn off all the pumps and boiler controls, eliminating that last trip out to the boiler.
Reactions: MickMorley
It's the same principal that guys are doing with their wood furnaces. Except they are opening the flap up front up when the temperature gets below a certain point. I'd highly ( cough cough wink wink ) recommend get a PID controller from Auber Instruments vs Amazon or Flebay. Auber has a number that you can call for support too.
I'm pretty these two models will do what you are wanting to do:
I'd probably call Auber and see what they recommend though since you'll be switching 120V vs 24V AC with a wood furnace.
Simple enough to do, especially with 2 separate PID controllers...I agree with @sloeffle , get an Auber, much better quality, directions, and support.
Yes, the SYL-2342 linked above is rated for 10A at 120v.
Are you wanting to shut off based on flue temp? If so, you will need a 3-4" long K type thermocouple too...
Reactions: sloeffle
Not quite the same but there is a simple timer on my Jetstream for the blower. A few dozen burns and can guess the time for a full load of softwood and hard wood pretty well already. Once blower is off the aqua stat scavenges the heat out with the circulator over the next hour or two.
I have an idea that I need to check out but I have a few things to wrap up , so it might not be for a day or 2 . I’m thinking my solution is in the programming.
Today I was able to wire my PID controller through the aquastat wiring . I’m using the Inkbird 106 vh with ssr , the aquastat will shut down the blower when hitting the high limit and the Inkbird PID will shut down the blower at a preset low temperature like around 160 and the other PID controller will totally shut down the boiler and pumps at a lower setting than the blower PID. The PID that controls the blower is just an unpowered switch, the wiring is a little different and the programming is different. I’m not sure if the settings are different for a different PID controller, but if you use the Inkbird, pm me and I’ll send you a wiring diagram and the settings parameters.
