This is embarrassing, but I have to put this out there. The door to the firebox on my outdoor Econoburn is stuck and I have run out of ideas on how to get it open. It's like it has been cemented shut. Has anyone run into this before? Thanks.
I'm assuming your damper door opens ok, and the firebox door lever is able to be flipped down, but the door can't be pulled open. That would mean that the door has been pinned shut by some of the best epoxy in the world - creosote. Try running a propane torch all the way around the door, where it meets the boiler flange. You will also probably cook some of the gasket, but it's likely you're going to need a new one of those anyway because sections of it may remain stuck to the boiler flange, and tear. Probably would also help to work a small paint scraper under the gasket as you move around the door. Sounds like you need to do more frequent creosote removal from the door and boiler flange - I use a hyde paint scraper for that job. Good luck with it!
Hi
Mine was stuck last fall as well.It was frozen gasket had some water in it from sitting outside.I used a prybar on the edge of the door and it opened.Good Luck
Thomas
a classic symptom of too much idling and any wood boiler is going to be susceptible to it. Are you using the boiler with storage? If not, shut 'er down, it's too warm out to be running the wood boiler. If you are running with storage, decrease the size of your fuel load or let your tank temps come down before re-firing. This amount of creosote sounds pretty excessive, if it continues year after year you could see leaking inside of ten years. Curious to hear more.
