Combining a couple posts...
georgeinct said:
Chris, thanks for the info.
I guess I agree with you about the indirect water heater, I was thinking of the on-demand because I am away a lot and also in the summer, I would think it would be more efficient than maintaining tank temperature all the time.
Another option might be to throw a couple solar HW panels up on your roof and do solar DHW in the summer. Or some folks have said that if they super insulate their indirect and throw an electric element in it, then the cost isn't that bad to use electric just in the summer time.
As for the size of the storage tank, I know GARN is highy regarded and mostly because it has large water storage. There smallest unit I believe is 1500 gallons and I do have a somewhat large house, 5000 s.f. even though seldom are all zones on.
All this being said, should I go larger than 1000? I have room for 1500 or even two 1000 gal. tanks. I definitely favor pressurized, less maintenance and more efficient. So is bigger better?
Bigger is possibly better if you want to be able to run longer between fires. The downside of bigger is that it will take longer to heat. Given that you have a larger size boiler, it probably wouldn't be bad to go for a larger tank... The other thing to keep in mind is that ALL tanks will lose some heat over time, so you are really better to keep your BTU's as fuel rather than hot water, so going to much oversized is probably not good either.... Maybe take a look at Garn's website and see what size they reccomend for your house, and match the tank size... The other dumb question is do you have basement access to get the tanks in and out? Propane tanks are big and heavy, and they don't flex in the middle...
Also, a chimney question if anyone knows the answer, I have an idea but am not sure. My chimney is lined has a flue size of 7"x11", I guess it is possible to install a stainless steel liner, but is it necessary. worth the added cost?
Not sure what the rules are on forced draft units, on a natural draft wood stove you aren't supposed to be more than 3x the flue outlet on an inside chimney or 2x on an outside chimney, and should ideally be the same. I think the Eko 80 uses an 8" outlet, which is ~48 sq in. Your flue would be 77 sq in, which is well within the limits, but not optimal. Assuming the flue is in good shape, I would say that the liner would be nice, but not essential.
TAlso, about tying the 2 boilers together allows for automatic kick in of the fossil fuel, but isn’t a loss of efficiency? The gas boiler becomes simply a conduit for heat loss because it will rarely be needed and the hot water of the other system has to pass through it if I understand correctly, no?
Why can’t the gas boiler be independent and still kick in if set off by some thermostat control? I will use it mostly when away. I am novice at this so please bear with me.
thanks again, georgehanks for you help
There is no reason the gas boiler can't be done as an independent system, but that would mean having to duplicate your entire heat distribution setup, with two sets of piping, radiation sources, etc. which is more than a bit of a waste. If you plumb the boilers in parallel then you get to re-use all the existing house plumbing with both units... If you do the search, you can find many sample layouts of how to do this, and links to manufacturer websites with even more ideas... Basically though each boiler usually has it's own pump and ties into the main loop seperately. If you use storage you want to set things up so the dino-boiler bypasses it, as you DON'T want to heat the storage with your gas boiler....
You end up with three heat sources - If the wood boiler is hot, heat from that, and if the boiler is putting out more than the current demand charge the storage. When the boiler goes out, run off the storage tank. If the storage tank isn't hot enough, fire up the gas boiler...
Hope this helps,
Gooserider
