Eco choice PS35 not lighting
Beans41
1
Wisconsin
I have an echo choice ps35. Just put a new door gasket on, new igniter, intake and exhaust are clean. Stove will only fire when I manually hit the reset button.
It will then heat to thermostat but after initial shut down, it will not refire to heat to the thermostat set temp. Any ideas?
If I understand you, you never get the call light on the control board, asking the stove to start up and run?
If you take thermostat wires off and connect together, does unit come on and run? If so, then obviously thermostat issue. If does not work, check thermostat wiring connection to stove, if call light comes on, but stove reset has to be pushed to start cycle, then could be control board, loose fitting control board or wiring.
Reactions: Ssyko and johneh
