Love the Heat
I usually do the chimney at the 50-60 bags mark..I would say approx 80 bags, of granulaco's. I'm about ready to do the full stove cleaning next...Yes this goes through the wall, its only 2 feet long.
Nice Job, my fan was not as dirty as this.
From what I see, you can service mine anytime you want![]()
Great. Thanks!DV....got mine from Drolet site which when you choose Web dealer it sends
you to Myfireplace.com .
Looks expensive but the kit contains 2 SETS
The gaskets are very fragile be ultra careful with them. What I noticed so far is that I had no creosote inside the stove, I do run it on high for a few hours at a time, maybe this helps prevent creosote?
Being able to cook on it would be handy.
hey...brand new to this forum....first time I joined a heating forum but my eco65 drove me to it. Have had it installed since Feb2013 and a lot of issues which I hope are just "growing pains" of a relatively new product from Drolet. on my 3rd igniter and just recently replaced the lower auger gearmotor....which apparently had an issue with the gearbox since the stove was new. Just feeling out what the long term looks like for this unit as I am beginning to doubt my choice when purchasing this unit. Is it only going to get worse?...or is there light at the end of the tunnel?
My ignitor has no issues, sometimes it ignites 10 times a day ...Maybe its a bad pressure pump, it so ODD to have so many fail...We're on our 5th ignitor. We'd only get 1 ignition out of them. 3 ignitions out if the last one. Drolet keeps sending new ones. Only issue we have had, the stove was installed in November of 2013.
Good point Hyfire, I usually scrape the pot at least every 2 days and the ash box usually need to be empty every 3 days when on 24/7..You should not operate it that long at a time without cleaning, what will happen is the burnpot holes will fill with ash and you will lose combustion efficiency. I see this on my magnehelic gauge starts to increase in draft you know your losing combustion air.. At least every 48 hours is a good schedule. You also want to burn it on high once a day for a bit to keep it cleaner...
